Hi, I have hit another problem, really sorry to be a bother. The repositories are getting stuck again on No valid PGP Data found.
I suspect, the network connectivity is getting disrupted during the virtual interface configuration and the DNS resolution is lost, though I am not sure, you would know better.
Its all good till here, though when the installation fails, I can delete the route 172.16.100.0/24 and force it to continue.
It seems like you have some specificity in your setup which is not covered by minione script.
Anyway I am glad you found a way to achieve your goal!
Hope you will enjoy OpenNebula and find it suitable for your tasks!
