I am trying to install miniONE on Ubuntu 20.04 KVM VM but ‘miniONE --verbose --lxd’ command stuck on ‘Installing OpenNebula packages’:
bash minione --verbose --lxd
Checks & detection
Checking distribution and version [Ubuntu 20.04 5.12] OK
Checking if OpenNebula repository exists OK
Checking LXD support for given version OK
Checking augeas is installed SKIP will try to install
Checking curl is installed OK
Checking free disk space OK
Checking directories from previous installation OK
Checking user from previous installation OK
Checking sshd service is running OK
Checking iptables are installed OK
Checking apt-transport-https is installed SKIP will try to install
Checking if gnupg is installed OK
Checking AppArmor SKIP will try to modify
Checking for present ssh key SKIP
Generating ssh keypair in /root/.ssh/id_rsa OK
Checking local interface [eth0] OK
Checking (iptables|netfilter)-persistent are installed SKIP will try to install
Checking minionebr interface is not present OK
Checking virtual network 172.16.100.0/24 is not routed OK
Checking presence of the market app: “CentOS 7” OKMain deployment steps:
Install OpenNebula frontend version 5.12
Configure bridge minionebr with IP 172.16.100.1/24
Enable NAT over eth0
Modify AppArmor
Install OpenNebula LXD node
Export appliance and update VM template
Install augeas-tools apt-transport-https iptables-persistent netfilter-persistentDo you agree? [yes/no]:
yesInstallation
Updating APT cache OK
Install augeas-tools apt-transport-https iptables-persistent netfilter-persistent OK
Creating bridge interface minionebr OK
Bring bridge interfaces up OK
Enabling IPv4 forward OK
Configuring NAT using iptables OK
Saving iptables changes OK
Installing DNSMasq OK
Starting DNSMasq OK
Configuring repositories OK
I would appreciate any hint on how to debug and fix that issue!
