Monitoring hosts
How I can set a minimum polling interval to monitoring hosts?
e.g.
I have 3 servers with shared storage.
Host hook enabled:
HOST_HOOK = [
    NAME      = "error",
    ON        = "ERROR",
    COMMAND   = "ft/host_error.rb",
    ARGUMENTS = "$ID -m -p 5",
    REMOTE    = "no" ]
I restart one of the servers, but VMs doesnt migrate, because HOST isnt in ERROR status.
But, I need minimal - 20 seconds to check HOST status.
I found this topic, but can`t understand how it can help me.
This is set in oned.conf:
http://docs.opennebula.org/5.2/deployment/open_cloud_host_setup/monitoring.html
You are interested in the -i argument for the collectd:
-i: Time in seconds of the monitorization push cycle. This parameter must be smaller than MONITORING_INTERVAL (see below), otherwise push monitorization will not be effective.
Thank you for your reply.
Its work, but I have a new problem. Im imitating the host problem (down interface), host in ERROR state, but HOST_HOOK doesn`t execute migrate VMs to another host.
VMs are still running on ERROR host, doesn`t ping, but in RUNNING status.
crmsh migrate services to another host.
Is there any idea?
Yes. Now it works.
Big thanks.
Now i try to minimise downtime)
