Currently I use NFS v4 as a datastore. The backend of datastore is an EMC Data Domain and seems that linux nfs client has an issue with it.
The ‘nfs: server XXX not responding, timed out’ messages are often observed at kvm nodes’ logs.
So I’ve decided to switch to NFS v3 for the test purpose and faced another problem, the KVM’s VM has failed to start:
Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy '/var/lib/one//datastores/101/45/deployment.15' 'one-kvm-node-01-int' 45 one-kvm-node-01-int
error: Failed to create domain from /var/lib/one//datastores/101/45/deployment.15
error: internal error: qemu unexpectedly closed the monitor: 2019-07-24T14:38:09.754413Z qemu-kvm: -drive file=/var/lib/one//datastores/101/45/disk.0,format=qcow2,if=none,id=drive-virtio-disk0,cache=none: Failed to lock byte 100
Could not create domain from /var/lib/one//datastores/101/45/deployment.15
ExitCode: 255
Failed to execute virtualization driver operation: deploy.
Error deploying virtual machine: Could not create domain from /var/lib/one//datastores/101/45/deployment.15
NFS v4 mount options at /etc/fstab:
soft,timeo=15,intr,rsize=32768,wsize=32768
NFS v3 mount options at /etc/fstab:
vers=3,hard,rsize=32768,wsize=32768
Any assistance with a ‘Failed to lock byte 100’ issue is more than welcome
KVM nodes run under CentOS kernel version 3.10.0-957.21.3.el7.x86_64
Opennebula version 5.8.1
Start the VM
KVM VM does not start within NFS v3 datastore
Switched back to NFS v4
VM up and running
