Hello community supporters, please help me how to solve this problem.
[Z0][VM][I]: New state is POWEROFF
Wed Apr 5 13:48:58 2023 [Z0][VM][I]: New LCM state is LCM_INIT
Wed Apr 5 13:49:24 2023 [Z0][VM][I]: New state is ACTIVE
Wed Apr 5 13:49:24 2023 [Z0][VM][I]: New LCM state is HOTPLUG_NIC_POWEROFF
Wed Apr 5 13:49:24 2023 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: Command execution failed (exit code: 255): /var/lib/one/remotes/vmm/vcenter/attach_nic ‘vm-8005_b277044f-6d95-438a-a037-e83016fd0b08’ ‘02:00:c6:a4:de:f4’ ‘vCenter Server Network’ ‘-’ ‘vcenter’ ‘one-27-0’ 27 VxRail-Virtual-SAN-Cluster
Wed Apr 5 13:49:30 2023 [Z0][VMM][E]: attach_nic: Attach NIC for VM vm-8005_b277044f-6d95-438a-a037-e83016fd0b08 on vCenter cluster VxRail-Virtual-SAN-Cluster failed due to “Cannot attach NIC to VM: InvalidRequest:
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: Cannot parse “4051930873” as an int value
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing serialized value of type int
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: at line 1, column 406
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing property “key” of static type int
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing serialized DataObject of type vim.vm.device.VirtualE1000e
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: at line 1, column 373
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing property “device” of static type VirtualDevice
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: at line 1, column 298
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing property “deviceChange” of static type ArrayOfVirtualDeviceConfigSpec
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing serialized DataObject of type vim.vm.ConfigSpec
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: at line 1, column 256
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing call information for method ReconfigVM_Task
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: at line 1, column 177
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing SOAP body
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: at line 1, column 167
Wed Apr 5 13:49:30 2023 [Z0][VMM][I]: while parsing SOAP envelope
Wed Apr 5 13:49:31 2023 [Z0][VMM][I]: at line 1, column 0
Wed Apr 5 13:49:31 2023 [Z0][VMM][I]: while parsing HTTP request for method reconfigure
Wed Apr 5 13:49:31 2023 [Z0][VMM][I]: on object of type vim.VirtualMachine
Wed Apr 5 13:49:31 2023 [Z0][VMM][I]: at line 1, column 0.”
Wed Apr 5 13:49:31 2023 [Z0][VMM][I]: Failed to execute virtualization driver operation: attach_nic.
Wed Apr 5 13:49:31 2023 [Z0][VMM][E]: ATTACHNIC: ERROR: attach_nic: Attach NIC for VM vm-8005_b277044f-6d95-438a-a037-e83016fd0b08 on vCenter cluster VxRail-Virtual-SAN-Cluster failed due to “Cannot attach NIC to VM: InvalidRequest: Cannot parse “4051930873” as an int value while parsing serialized value of type int at line 1, column 406 while parsing property “key” of static type int while parsing serialized DataObject of type vim.vm.device.VirtualE1000e at line 1, column 373 while parsing property “device” of static type VirtualDevice while parsing serialized DataObject of type vim.vm.device.VirtualDeviceSpec at line 1, column 298 while parsing property “deviceChange” of static type ArrayOfVirtualDeviceConfigSpec while parsing serialized DataObject of type vim.vm.ConfigSpec at line 1, column 256 while parsing call information for method ReconfigVM_Task at line 1, column 177 while parsing SOAP body at line 1, column 167 while parsing SOAP envelope at line 1, column 0 while parsing HTTP request for method reconfigure on object of type vim.VirtualMachine at line 1, column 0.”
Wed Apr 5 13:49:31 2023 [Z0][VM][I]: New state is POWEROFF
Wed Apr 5 13:49:31 2023 [Z0][VM][I]: New LCM state is LCM_INIT
