after an host reboots, the VM’s are in state “UNKNOWN”. Now I try to find a VM-Hook, to start my VM’s. I tried all described hooks, but non ist triggered in UNKNOWN. I tried CREATE and this one works like described.
Example on my VM #4:
The state:
oneadmin@devel:~$ onevm show 4
VIRTUAL MACHINE 4 INFORMATION
USER : oneadmin
GROUP : oneadmin
STATE : ACTIVE
LCM_STATE : UNKNOWN
RESCHED : No
HOST : localhost
The VM-Hook:
M_HOOK = [
name = “unknown”,
on = “CUSTOM”,
state = “ACTIVE”,
lcm_state = “UNKNOWN”,
command = “/var/lib/one/remotes/hooks/eurogard/start_unknown.sh”,
arguments = “$ID $PREV_STATE $PREV_LCM_STATE”,
remote = “no” ]
The Logs:
root@devel:~# date
Do 30. Jul 13:48:19 CEST 2015
root@devel:~# tail /var/log/one/4.log
Wed Jul 29 17:27:01 2015 [LCM][I]: New VM state is BOOT_UNKNOWN
Wed Jul 29 17:27:01 2015 [VMM][I]: Generating deployment file: /var/lib/one/vms/4/deployment.0
Wed Jul 29 17:27:01 2015 [VMM][I]: ExitCode: 0
Wed Jul 29 17:27:01 2015 [VMM][I]: Successfully execute network driver operation: pre.
Wed Jul 29 17:27:02 2015 [VMM][I]: ExitCode: 0
Wed Jul 29 17:27:02 2015 [VMM][I]: Successfully execute virtualization driver operation: deploy.
Wed Jul 29 17:27:02 2015 [VMM][I]: Successfully execute network driver operation: post.
Wed Jul 29 17:27:02 2015 [LCM][I]: New VM state is RUNNING
Wed Jul 29 17:31:33 2015 [LCM][I]: New VM state is UNKNOWN
root@devel:~# grep -i hook /var/log/one/oned.log
VM_HOOK=ARGUMENTS=$ID $PREV_STATE $PREV_LCM_STATE,COMMAND=/var/lib/one/remotes/hooks/eurogard/start_unknown.sh,LCM_STATE=UNKNOWN,NAME=unknown,ON=CUSTOM,REMOTE=no,STATE=ACTIVE
VM_HOOK=ARGUMENTS=$TEMPLATE,COMMAND=/var/lib/one/remotes/hooks/eurogard/set_fw_rule.sh,NAME=create,ON=CREATE,REMOTE=no
Thu Jul 30 10:54:23 2015 [HKM][I]: Starting Hook Manager…
Thu Jul 30 10:54:23 2015 [HKM][I]: Hook Manager started.
Thu Jul 30 10:54:25 2015 [HKM][I]: Loading Hook Manager driver.
Thu Jul 30 10:54:25 2015 [HKM][I]: Hook Manager loaded
The only logentries from vm #4 are from yesterday, but i rebooted the host many times today. It seems opennebula does not touch the VM, so no hook can be triggerd. Manualy I can boot this VM easily.
What I’m doing wrong?
Thanks, Falk
