Node Launching taking 5 minutes
Here is the node launch details
Tue Feb 4 16:12:17 2025 [Z0][VM][I]: New state is ACTIVE
Tue Feb 4 16:12:17 2025 [Z0][VM][I]: New LCM state is PROLOG
Tue Feb 4 16:13:21 2025 [Z0][VM][I]: New LCM state is BOOT
Tue Feb 4 16:13:21 2025 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/228561/deployment.0
Tue Feb 4 16:17:53 2025 [Z0][LCM][I]: VM reported RUNNING by the drivers
Tue Feb 4 16:17:53 2025 [Z0][VM][I]: New LCM state is RUNNING
Its taking nearly 5 minutes to come up the node with the image size of 15gb.
Hi @mac,
You have asked a similar question here: Opennebula too slow
Without giving us much hints or details, could you please ellaborate a bit more?
Thank you,
I have configured as follows
One Frontend server
One DB Server
One Image server withmounted with Frontend server
Have added 60 hosts into the Opennebula for deploying the VMs (auto deployement)
Each vm takes 5 minutes to deploye it.
Whereas in AWS while i am doing an testing the VM deployed in 30 seconds and the node is coming up over the network (tested with ping)
Do you have any error log?
With this is complicated to guess what could be, since it could be:
  1. Resource Constraints in terms of the CPU, or storage resources.
  2. Issues with the connectivity between the server and the node. It might be a packet loss, for example.
  3. Issues with the Storage backend.
  4. Hypervisor Configuration problem
  5. Is the AWS instance configured the same?, does it have 60 hosts as well?
Also, are you running the latest version of OpenNebula?
Please check /var/log/one/oned.log (as we already asked you on the other topic), and paste the information.
Thanks,
log (36.9 KB)
please find the logs of /var/log/one/oned.log
