Running Version: 5.4.6
I have a problem while creating a VM template and add COST together. It got a error if add Memory and Disk parameters with following error
It appears there was a server exception. Please check server’s log.
However, it could not find related log from /var/log/one/oned.log
Could you please advise what is the problem?
Thanks!
juanmont
(Juan Jose Montiel Cano)
2
Hello
can you put here the VM Template and the error?
Regards!
Juan Jose
Following is template after build up. Image is download from Apps
But I could not find the log from /var/log/one/oned.log
only can see the error message at Web GUI there was a server exception. Please check server’s log
CONTEXT = [
NETWORK = “YES”,
SSH_PUBLIC_KEY = “$USER[SSH_PUBLIC_KEY]”,
START_SCRIPT_BASE64 = “c2VkIC1pIC1lICdzL1Bhc3N3b3JkQXV0aGVudGljYXRpb24gLiovUGFzc3dvcmRBdXRoZW50aWNhdGlvbiB5ZXMvJyAvZXRjL3NzaC9zc2hkX2NvbmZpZwpzZWQgLWkgLWUgJ3MvUGVybWl0Um9vdExvZ2luIC4qL1Blcm1pdFJvb3RMb2dpbiB5ZXMvJyAvZXRjL3NzaC9zc2hkX2NvbmZpZwpzeXN0ZW1jdGwgcmVzdGFydCBzc2hk” ]
CPU = "1"
CPU_COST = "0.02"
DISK = [
IMAGE = “CentOS 7 - KVM”,
IMAGE_UNAME = “oneadmin” ]
GRAPHICS = [
LISTEN = “0.0.0.0”,
TYPE = “VNC” ]
HYPERVISOR = "kvm"
LOGO = "images/logos/centos.png"
MEMORY = "1024"
MEMORY_UNIT_COST = "MB"
NIC = [
DNS = “8.8.8.8”,
GATEWAY = “1.2.3.1”,
NETWORK = “wan1”,
NETWORK_MASK = “255.255.255.224”,
NETWORK_UNAME = “oneadmin” ]
OS = [
ARCH = “x86_64”,
BOOT = “disk0” ]
Thanks!
