I have installed OpenNebula 5.0.2 from the Debian repository, haven’t touched any configuration.
# systemctl status opennebula
● opennebula.service - OpenNebula Cloud Controller Daemon
Loaded: loaded (/lib/systemd/system/opennebula.service; enabled)
Active: failed (Result: exit-code) since Tue 2016-09-20 12:14:32 CEST; 3s ago
Process: 3246 ExecStop=/bin/kill -TERM $MAINPID (code=exited, status=1/FAILURE)
Process: 3236 ExecStart=/usr/bin/oned -f (code=exited, status=255)
Process: 3229 ExecStartPre=/usr/sbin/logrotate -s /tmp/logrotate.state -f /etc/logrotate.d/opennebula (code=exited, status=0/SUCCESS)
Process: 3226 ExecStartPre=/bin/chown oneadmin:oneadmin /var/log/one (code=exited, status=0/SUCCESS)
Process: 3222 ExecStartPre=/bin/mkdir -p /var/log/one (code=exited, status=0/SUCCESS)
Main PID: 3236 (code=exited, status=255)
Sep 20 12:14:32 azor kill[3246]: -<signal>, -s, --signal <signal>
Sep 20 12:14:32 azor kill[3246]: specify the <signal> to be sent
Sep 20 12:14:32 azor kill[3246]: -l, --list=[<signal>] list all signal names, or convert one to a name
Sep 20 12:14:32 azor kill[3246]: -L, --table list all signal names in a nice table
Sep 20 12:14:32 azor kill[3246]: -h, --help display this help and exit
Sep 20 12:14:32 azor kill[3246]: -V, --version output version information and exit
Sep 20 12:14:32 azor kill[3246]: For more details see kill(1).
Sep 20 12:14:32 azor systemd[1]: opennebula.service: control process exited, code=exited status=1
Sep 20 12:14:32 azor systemd[1]: Stopped OpenNebula Cloud Controller Daemon.
Sep 20 12:14:32 azor systemd[1]: Unit opennebula.service entered failed state.
The /var/log/one/oned.log file is empty. Next I switched to oneadmin user and tried to run oned directly.
$ oned -f
[1] 3496 segmentation fault oned -f
The database got created and the config dump is present in /var/lib/one.
$ ll
total 88K
-rw-r--r-- 1 oneadmin oneadmin 5.8K Sep 20 12:18 config
drwxr-xr-x 4 oneadmin oneadmin 4.0K Sep 20 12:00 datastores
-rw-r--r-- 1 oneadmin oneadmin 61K Sep 20 12:18 one.db
drwxr-xr-x 10 oneadmin oneadmin 4.0K Sep 20 12:00 remotes
drwxr-xr-x 2 oneadmin oneadmin 4.0K Jul 22 17:50 vms
$ cat /var/lib/one/config
AUTH_MAD=AUTHN=ssh,x509,ldap,server_cipher,server_x509,EXECUTABLE=one_auth_mad
AUTH_MAD_CONF=NAME=core,PASSWORD_CHANGE=YES
AUTH_MAD_CONF=NAME=public,PASSWORD_CHANGE=NO
AUTH_MAD_CONF=NAME=ssh,PASSWORD_CHANGE=YES
AUTH_MAD_CONF=NAME=x509,PASSWORD_CHANGE=NO
AUTH_MAD_CONF=NAME=ldap,PASSWORD_CHANGE=YES
AUTH_MAD_CONF=NAME=server_cipher,PASSWORD_CHANGE=NO
AUTH_MAD_CONF=NAME=server_x509,PASSWORD_CHANGE=NO
DATASTORE_CAPACITY_CHECK=yes
DATASTORE_LOCATION=/var/lib/one//datastores
DATASTORE_MAD=ARGUMENTS=-t 15 -d dummy,fs,lvm,ceph,dev,iscsi_libvirt,vcenter -s shared,ssh,ceph,fs_lvm,qcow2,EXECUTABLE=one_datastore
DB=BACKEND=sqlite
DEFAULT_AUTH=default
DEFAULT_CDROM_DEVICE_PREFIX=hd
DEFAULT_COST=CPU_COST=0,DISK_COST=0,MEMORY_COST=0
DEFAULT_DEVICE_PREFIX=hd
DEFAULT_IMAGE_TYPE=OS
DEFAULT_UMASK=177
DS_MAD_CONF=MARKETPLACE_ACTIONS=export,NAME=ceph,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=DISK_TYPE,BRIDGE_LIST
DS_MAD_CONF=NAME=dev,PERSISTENT_ONLY=YES,REQUIRED_ATTRS=DISK_TYPE
DS_MAD_CONF=NAME=iscsi_libvirt,PERSISTENT_ONLY=YES,REQUIRED_ATTRS=DISK_TYPE,ISCSI_HOST
DS_MAD_CONF=NAME=dummy,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=
DS_MAD_CONF=MARKETPLACE_ACTIONS=export,NAME=fs,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=
DS_MAD_CONF=NAME=lvm,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=DISK_TYPE,BRIDGE_LIST
DS_MAD_CONF=MARKETPLACE_ACTIONS=export,NAME=vcenter,PERSISTENT_ONLY=YES,REQUIRED_ATTRS=VCENTER_CLUSTER
DS_MAD_CONF=NAME=shared,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=
DS_MAD_CONF=NAME=ssh,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=
DS_MAD_CONF=NAME=vmfs,PERSISTENT_ONLY=NO,REQUIRED_ATTRS=BRIDGE_LIST
ENABLE_OTHER_PERMISSIONS=YES
FEDERATION=MASTER_ONED=,MODE=STANDALONE,ZONE_ID=0
HM_MAD=EXECUTABLE=one_hm
HOST_MONITORING_EXPIRATION_TIME=43200
HOST_PER_INTERVAL=15
IMAGE_RESTRICTED_ATTR=SOURCE
IM_MAD=ARGUMENTS=-p 4124 -f 5 -t 50 -i 20,EXECUTABLE=collectd,NAME=collectd
IM_MAD=ARGUMENTS=-r 3 -t 15 kvm,EXECUTABLE=one_im_ssh,NAME=kvm,SUNSTONE_NAME=KVM
INHERIT_DATASTORE_ATTR=CEPH_HOST
INHERIT_DATASTORE_ATTR=CEPH_SECRET
INHERIT_DATASTORE_ATTR=CEPH_USER
INHERIT_DATASTORE_ATTR=CEPH_CONF
INHERIT_DATASTORE_ATTR=POOL_NAME
INHERIT_DATASTORE_ATTR=ISCSI_USER
INHERIT_DATASTORE_ATTR=ISCSI_USAGE
INHERIT_DATASTORE_ATTR=ISCSI_HOST
INHERIT_DATASTORE_ATTR=GLUSTER_HOST
INHERIT_DATASTORE_ATTR=GLUSTER_VOLUME
INHERIT_DATASTORE_ATTR=DISK_TYPE
INHERIT_DATASTORE_ATTR=ADAPTER_TYPE
INHERIT_IMAGE_ATTR=ISCSI_USER
INHERIT_IMAGE_ATTR=ISCSI_USAGE
INHERIT_IMAGE_ATTR=ISCSI_HOST
INHERIT_IMAGE_ATTR=ISCSI_IQN
INHERIT_IMAGE_ATTR=DISK_TYPE
INHERIT_IMAGE_ATTR=ADAPTER_TYPE
INHERIT_VNET_ATTR=VLAN_TAGGED_ID
INHERIT_VNET_ATTR=FILTER_IP_SPOOFING
INHERIT_VNET_ATTR=FILTER_MAC_SPOOFING
INHERIT_VNET_ATTR=MTU
KEEPALIVE_MAX_CONN=30
KEEPALIVE_TIMEOUT=15
LISTEN_ADDRESS=0.0.0.0
LOG=DEBUG_LEVEL=3,SYSTEM=file
LOG_CALL_FORMAT=Req:%i UID:%u %m invoked %l
MAC_PREFIX=02:00
MANAGER_TIMER=15
MARKET_MAD=ARGUMENTS=-t 15 -m http,s3,one,EXECUTABLE=one_market
MARKET_MAD_CONF=APP_ACTIONS=monitor,NAME=one,PUBLIC=yes,REQUIRED_ATTRS=,SUNSTONE_NAME=OpenNebula.org Marketplace
MARKET_MAD_CONF=APP_ACTIONS=create, delete, monitor,NAME=http,REQUIRED_ATTRS=BASE_URL,PUBLIC_DIR,SUNSTONE_NAME=HTTP server
MARKET_MAD_CONF=APP_ACTIONS=create, delete, monitor,NAME=s3,REQUIRED_ATTRS=ACCESS_KEY_ID,SECRET_ACCESS_KEY,REGION,BUCKET,SUNSTONE_NAME=Amazon S3
MAX_CONN=15
MAX_CONN_BACKLOG=15
MESSAGE_SIZE=1073741824
MONITORING_INTERVAL=60
MONITORING_THREADS=50
NETWORK_SIZE=254
PCI_PASSTHROUGH_BUS=0x01
PORT=2633
RPC_LOG=NO
SCRIPTS_REMOTE_DIR=/var/tmp/one
SESSION_EXPIRATION_TIME=900
TIMEOUT=15
TM_MAD=ARGUMENTS=-t 15 -d dummy,lvm,shared,fs_lvm,qcow2,ssh,ceph,dev,vcenter,iscsi_libvirt,EXECUTABLE=one_tm
TM_MAD_CONF=CLONE_TARGET=SYSTEM,DS_MIGRATE=YES,LN_TARGET=NONE,NAME=dummy,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SELF,LN_TARGET=NONE,NAME=lvm,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SYSTEM,DS_MIGRATE=YES,LN_TARGET=NONE,NAME=shared,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=SYSTEM,NAME=fs_lvm,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SYSTEM,LN_TARGET=NONE,NAME=qcow2,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SYSTEM,DS_MIGRATE=YES,LN_TARGET=SYSTEM,NAME=ssh,SHARED=NO
TM_MAD_CONF=CLONE_TARGET=SELF,DS_MIGRATE=NO,LN_TARGET=NONE,NAME=ceph,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SELF,DS_MIGRATE=NO,LN_TARGET=NONE,NAME=iscsi_libvirt,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=NONE,LN_TARGET=NONE,NAME=dev,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=NONE,LN_TARGET=NONE,NAME=vcenter,SHARED=YES
TM_MAD_CONF=CLONE_TARGET=SYSTEM,DS_MIGRATE=NO,LN_TARGET=NONE,NAME=vmfs,SHARED=YES
VLAN_IDS=RESERVED=0, 1, 4095,START=2
VM_INDIVIDUAL_MONITORING=no
VM_MAD=ARGUMENTS=-t 15 -r 0 kvm,DEFAULT=vmm_exec/vmm_exec_kvm.conf,EXECUTABLE=one_vmm_exec,IMPORTED_VMS_ACTIONS=terminate, terminate-hard, hold, release, suspend,
resume, delete, reboot, reboot-hard, resched, unresched, disk-attach,
disk-detach, nic-attach, nic-detach, snap-create, snap-delete,KEEP_SNAPSHOTS=no,NAME=kvm,SUNSTONE_NAME=KVM,TYPE=kvm
VM_MONITORING_EXPIRATION_TIME=14400
VM_PER_INTERVAL=5
VM_RESTRICTED_ATTR=CONTEXT/FILES
VM_RESTRICTED_ATTR=NIC/MAC
VM_RESTRICTED_ATTR=NIC/VLAN_ID
VM_RESTRICTED_ATTR=NIC/BRIDGE
VM_RESTRICTED_ATTR=NIC_DEFAULT/MAC
VM_RESTRICTED_ATTR=NIC_DEFAULT/VLAN_ID
VM_RESTRICTED_ATTR=NIC_DEFAULT/BRIDGE
VM_RESTRICTED_ATTR=DISK/TOTAL_BYTES_SEC
VM_RESTRICTED_ATTR=DISK/READ_BYTES_SEC
VM_RESTRICTED_ATTR=DISK/WRITE_BYTES_SEC
VM_RESTRICTED_ATTR=DISK/TOTAL_IOPS_SEC
VM_RESTRICTED_ATTR=DISK/READ_IOPS_SEC
VM_RESTRICTED_ATTR=DISK/WRITE_IOPS_SEC
VM_RESTRICTED_ATTR=DISK/ORIGINAL_SIZE
VM_RESTRICTED_ATTR=CPU_COST
VM_RESTRICTED_ATTR=MEMORY_COST
VM_RESTRICTED_ATTR=DISK_COST
VM_RESTRICTED_ATTR=PCI
VM_RESTRICTED_ATTR=USER_INPUTS
VM_SUBMIT_ON_HOLD=NO
VNC_PORTS=START=5900
VNET_RESTRICTED_ATTR=VN_MAD
VNET_RESTRICTED_ATTR=PHYDEV
VNET_RESTRICTED_ATTR=VLAN_ID
VNET_RESTRICTED_ATTR=BRIDGE
VNET_RESTRICTED_ATTR=AR/VN_MAD
VNET_RESTRICTED_ATTR=AR/PHYDEV
VNET_RESTRICTED_ATTR=AR/VLAN_ID
VNET_RESTRICTED_ATTR=AR/BRIDGE
VXLAN_IDS=START=2
The machine is running latest Debian Jessie.
# cat /etc/debian_version
8.6
# uname -a
Linux azor 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u1 (2016-09-03) x86_64 GNU/Linux
Why is this happening? What can be done to solve it? Thank you.
