Hi all,
we are still having problems with various quotas being out of sync with reality - users having negative number of running VMs, users with no VM running but non-zero “running memory”, etc. So I need to run onedb fsck
occasionally. Today, it refused to start:
# onedb fsck
Version mismatch: fsck file is for version
Shared: 6.6.0, Local: 6.6.0
Current database is version
Shared: , Local:
The error message was not very helpful. But OpenNebula 6.6.0 has been running correctly, so database version should be correct. After trying many things, I tried to run also various other onedb
subcommands:
onedb show-body vm --id 1234
displayed a correct XML data of that VM. But then onedb history
failed with somewhat meaningful error message:
# onedb history
Error connecting to DB: Mysql2::Error: Unsupported charset: '"utf8mb3"'
After re-reading the onedb
manual page, I guessed that I could try onedb fsck --charset utf8
, as I didn’t know what utf8mb3
means :-). And indeed it worked.
So, why do OpenNebula daemons and some onedb
subcommands work, but onedb history
connects with the wrong charset, and onedb fsck
fails even without a meaningful error message?
Also, does anybody else see miscalculated resource usage for various quotas? I have been seeing it for many ONe versions back.
Thanks,
-Yenya
