Onehost sync with/without the "--rsync" option
when I execute “onehost sync --force” I get the following message:
  • Adding to upgrade
    [========================================] 1/1
    Failed to update the following hosts:
After executing "“onehost sync --force --rsync” everything looks fine and the scripts have been copied.
What is the difference of copying the scripts with/without the “–rsync” option ?
Best regards
Hans Bienert
Hi Hans,
which os do you use on your target hosts?
Regards
Stephan
Hi @Hans_Bienert
With --rsync you will also update permissions/ownerships in the remote hosts
