Openebula 4.12 + (addon-sheepdog)
Hi)))
Installing Opennebula frontend ( Centos 7), Opennebula Node ( Centos 7), Sheepdog Node (storage) (Centos 7)
I am reading Instruction:
this is debian
oneadmin have to be able to execute “dog” as root without password
cat >/etc/sudoers.d/opennebula-sheepdog <<EOF
Cmnd_Alias ONE_SHEEPDOG = /usr/sbin/dog
oneadmin ALL=(ALL) NOPASSWD: ONE_SHEEPDOG
EOF
If Centos (RPM) Cmnd_Alias ONE_SHEEPDOG = /usr/bin/dog
after Added storage Opennebula Frontend
( ok !!))) Works Datastores shows Opennebula Frontend
But when i am created Virtual Machine ( mistake)
Log:
Thu Apr 21 21:40:35 2016 : Error executing image transfer script: Error cloning one-3 to one-3-12-1 in oneb.node1
(oned.log) Log:
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG I 12 Command execution fail: /var/lib/one/remotes/tm/sheepdog/clone opennebula:one-3 oneb.node1:/var/lib/one//datastores/0/12/disk.1 12 100
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG E 12 clone: Command "set -e
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG I 12 sudo dog vdi snapshot -a 127.0.0.1 -s clone_12-1 one-3
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG I 12 sudo dog vdi clone -a 127.0.0.1 -s clone_12-1 one-3 one-3-12-1
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG I 12 sudo dog vdi delete -a 127.0.0.1 -s clone_12-1 one-3" failed: sudo: no tty present and no askpass program specified
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG E 12 Error cloning one-3 to one-3-12-1 in oneb.node1
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: LOG I 12 ExitCode: 1
Thu Apr 21 21:40:35 2016 [Z0][TM][D]: Message received: TRANSFER FAILURE 12 Error cloning one-3 to one-3-12-1 in oneb.node1
What happens??
What wrong ???
I would be grateful for the help )))
Hi Tesla,
This is the error hint:
In the sudoers file you have /usr/sbin/dog. Try adding /sbin/dog too and try again. On CentOS7 /sbin is symlink to /usr/sbin/ and i bet that for some reason the third command is trying to use /sbin/dog which has no sudo rights.
Another solution is to replace in scripts_common.sh the variable DOG=dog to DOG=/usr/sbin/dog. This way you will be sure that you are calling the sudo-enabled path to the binary.
Kind Regards,
Hmm I am doing this, but it still does not work
But when Opennebula frontend – (create template only CD (without HDD), and create virtual machine, interesting log:
Fri Apr 22 17:17:40 2016 [Z0][ReM][D]: Req:1984 UID:2 VirtualMachinePoolInfo invoked , -2, 0, -2000, -1
Fri Apr 22 17:17:40 2016 [Z0][ReM][D]: Req:1984 UID:2 VirtualMachinePoolInfo result SUCCESS, “<VM_POOL>18<…”
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: LOG I 18 Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy ‘/var/lib/one//datastores/0/18/deployment.0’ ‘oneb.node1’ 18 oneb.node1
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: LOG I 18 error: Failed to create domain from /var/lib/one//datastores/0/18/deployment.0
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: LOG I 18 error: internal error: process exited while connecting to monitor: 2016-04-22T13:17:40.285277Z qemu-kvm: -drive file=sheepdog:one-6,if=none,id=drive-ide0-0-0,readonly=on,format=raw,cache=none: could not open disk image sheepdog:one-6: Driver ‘sheepdog’ is not whitelisted
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: LOG E 18 Could not create domain from /var/lib/one//datastores/0/18/deployment.0
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: LOG I 18 ExitCode: 255
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: LOG I 18 Failed to execute virtualization driver operation: deploy.
Fri Apr 22 17:17:40 2016 [Z0][VMM][D]: Message received: DEPLOY FAILURE 18 Could not create domain from /var/lib/one//datastores/0/18/deployment.0
Maybe this problem ??
Maybe recreate RPM package qemu-kvm ???
with options:
configure.
–block-drv-rw-whitelist=qcow2,raw,file,host_device,nbd,iscsi,gluster,rbd,sheepdog
Definitely, then probably you should patch the sheepdog addon scripts with the unlock solution from same thread…
I am recreate RPM package Qemu-KVM ( with white list
Installing? and after that I have new errors (((
Tue Apr 26 20:10:17 2016 [Z0][ReM][D]: Req:6080 UID:0 VirtualMachineDeploy result SUCCESS, 25
Tue Apr 26 20:10:18 2016 [Z0][TM][D]: Message received: TRANSFER SUCCESS 25 -
Tue Apr 26 20:10:18 2016 [Z0][VMM][D]: Message received: LOG I 25 ExitCode: 0
Tue Apr 26 20:10:18 2016 [Z0][VMM][D]: Message received: LOG I 25 Successfully execute network driver operation: pre.
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG I 25 Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy ‘/var/lib/one//datastores/0/25/deployment.0’ ‘oneb.node1’ 25 oneb.node1
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG I 25 error: Failed to create domain from /var/lib/one//datastores/0/25/deployment.0
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG I 25 error: internal error: process exited while connecting to monitor: 2016-04-26T16:10:17.963033Z qemu-kvm: -drive file=sheepdog:one-8,if=none,id=drive-ide0-0-0,readonly=on,format=raw,cache=none: Failed to connect to socket: Connection refused
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG I 25 2016-04-26T16:10:17.963302Z qemu-kvm: -drive file=sheepdog:one-8,if=none,id=drive-ide0-0-0,readonly=on,format=raw,cache=none: could not open disk image sheepdog:one-8: Could not open ‘sheepdog:one-8’: Operation not permitted
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG E 25 Could not create domain from /var/lib/one//datastores/0/25/deployment.0
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG I 25 ExitCode: 255
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: LOG I 25 Failed to execute virtualization driver operation: deploy.
Tue Apr 26 20:10:19 2016 [Z0][VMM][D]: Message received: DEPLOY FAILURE 25 Could not create domain from /var/lib/one//datastores/0/25/deployment.0
Hmm…
When if ( I am Installing template only (CDROM ) this error
When I am add template CD+ HDD ( another error )
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG I 26 Command execution fail: /var/lib/one/remotes/tm/sheepdog/clone opennebula:one-9 oneb.node1:/var/lib/one//datastores/0/26/disk.1 26 104
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG E 26 clone: Command "set -e
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG I 26 sudo dog vdi snapshot -a 127.0.0.1 -s clone_26-1 one-9
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG I 26 sudo dog vdi clone -a 127.0.0.1 -s clone_26-1 one-9 one-9-26-1
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG I 26 sudo dog vdi delete -a 127.0.0.1 -s clone_26-1 one-9" failed: sudo: no tty present and no askpass program specified
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG E 26 Error cloning one-9 to one-9-26-1 in oneb.node1
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: LOG I 26 ExitCode: 1
Tue Apr 26 20:26:48 2016 [Z0][TM][D]: Message received: TRANSFER FAILURE 26 Error cloning one-9 to one-9-26-1 in oneb.node1
Ok)) this its great work !!)))
  1. — onebstore —
    installing zookeeper-native
    wget -O /etc/yum.repos.d/cloudera-cdh5.repo https://archive.cloudera.com/cdh5/redhat/7/x86_64/cdh/cloudera-cdh5.repo
    yum install zookeeper-native
    yum localinstall zookee*
    yum localinstall sheep*
    I am create RPM packagezookeeper-3.4.8-1.x86_64.rpm (2.7 MB)sheepdog-1.0_rc0-1.el7.centos.x86_64.rpm (307.1 KB)
Defaults:oneadmin !requiretty
Defaults:oneadmin visiblepw
oneadmin ALL=(ALL:ALL) ALL
oneadmin ALL=(ALL) NOPASSWD: ALL
Cmnd_Alias ONE_SHEEPDOG = /usr/sbin/dog, /sbin/dog, /usr/bin/dog, /bin/dog
  1. ----node----
    I am recreate RPM — because mistake — White list sheepdog
    libcacard-1.5.3-105.el7.centos.3.x86_64.rpm (226.9 KB)libcacard-devel-1.5.3-105.el7.centos.3.x86_64.rpm (192.6 KB)libcacard-tools-1.5.3-105.el7.centos.3.x86_64.rpm (192.1 KB)qemu-img-1.5.3-105.el7.centos.3.x86_64.rpm (655.9 KB)qemu-kvm-1.5.3-105.el7.centos.3.x86_64.rpm (1.8 MB)qemu-kvm-common-1.5.3-105.el7.centos.3.x86_64.rpm (389.4 KB)
qemu-kvm-tools-1.5.3-105.el7.centos.3.x86_64.rpm (187.7 KB)
and ----
create sheepdog — getaway
https://bugs.launchpad.net/sheepdog-project/+bug/1337848
