OpenNebula Developer Request: opennebula-tools compiled for arm64
I’m managing a 30 node cluster from an arm64 laptop, and would like to run the tools locally without having to emulate amd64 on a separate VM.
Could you add arm64 compilation to the opennebula packages in the official repository please? opennebula-tools (over flow and provision), if I had to pick one.
Thanks!
+1 for the idea. I’m running Ampere CPU Q64-22
You should be able to install the opennebula-cli gem and point your CLI to where OpenNebula is running.
