Dear All,
Please help to enlighten me regarding of this error while creating VM:
Tue Jul 28 22:17:39 2020 [Z0][VM][I]: New state is ACTIVE
Tue Jul 28 22:17:39 2020 [Z0][VM][I]: New LCM state is PROLOG
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: Command execution failed (exit code: 1): /var/lib/one/remotes/tm/fs_lvm/clone pmbhost.net:/var/lib/one//datastores/101/b4fbeacc82a678679e6b87d28abca0ab node3.pmbhost.net:/var/lib/one//datastores/100/5/disk.0 5 101
Tue Jul 28 22:17:41 2020 [Z0][TM][E]: clone: Command " set -e -o pipefail
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: mkdir -p /var/lib/one/datastores/100/5
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: hostname -f >“/var/lib/one/datastores/100/5/.host” || :
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: # zero trailing space
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: if [ “yes” = “yes” ]; then
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: LVSIZE=$(sudo lvs --nosuffix --noheadings --units B -o lv_size “/dev/vg-one-100/lv-one-5-0” | tr -d ‘[:blank:]’)
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: dd if=/dev/zero of=“/dev/vg-one-100/lv-one-5-0” bs=64k oflag=seek_bytes iflag=count_bytes seek=“4293918720” count=“$(( LVSIZE - 4293918720 ))”
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: fi
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: qemu-img convert -O raw “/var/lib/one/datastores/101/b4fbeacc82a678679e6b87d28abca0ab” “/dev/vg-one-100/lv-one-5-0”
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: rm -f “/var/lib/one/datastores/100/5/disk.0”
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: ln -s “/dev/vg-one-100/lv-one-5-0” “/var/lib/one/datastores/100/5/disk.0"” failed: 16+0 records in
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: 16+0 records out
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: 1048576 bytes (1.0 MB, 1.0 MiB) copied, 0.00834615 s, 126 MB/s
Tue Jul 28 22:17:41 2020 [Z0][TM][I]: qemu-img: Could not open ‘/var/lib/one/datastores/101/b4fbeacc82a678679e6b87d28abca0ab’: Could not open ‘/var/lib/one/datastores/101/b4fbeacc82a678679e6b87d28abca0ab’: No such file or directory
Tue Jul 28 22:17:41 2020 [Z0][TM][E]: Error cloning /var/lib/one/datastores/101/b4fbeacc82a678679e6b87d28abca0ab to lv-one-5-0
Tue Jul 28 22:17:41 2020 [Z0][TM][E]: Error executing image transfer script: Error cloning /var/lib/one/datastores/101/b4fbeacc82a678679e6b87d28abca0ab to lv-one-5-0
Tue Jul 28 22:17:41 2020 [Z0][VM][I]: New LCM state is PROLOG_FAILURE
Best Regards,
Jhonny
