OpenNebula TP containerized
Hi…
I just tried containerized opennebula using docker-compose as follow the Containerized Deployment (TP) — OpenNebula 6.2.2 documentation
When I run the docker-compose for multi-container I have an error like below:
opennebula-provision_1 | 2022-02-06 11:18:51,320 INFO spawned: ‘bootstrap’ with pid 65
opennebula-provision_1 | 2022-02-06 11:18:51,322 INFO spawned: ‘crond’ with pid 66
opennebula-provision_1 | 2022-02-06 11:18:51,324 INFO spawned: ‘supervisor-listener’ with pid 67
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: FRONTEND: Starting the initial bootstrap service…
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: FRONTEND: Set trap on exit
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: FRONTEND: Load all saved image parameters by the entrypoint
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: ***************************************
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: ********** BOOTSTRAP START **********
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: FRONTEND: Bootstrap for OpenNebula service: oneprovision
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6: ETCDCTL: Wait until the etcd service is ready…
opennebula-provision_1 | parse error: Invalid numeric literal at line 1, column 10
opennebula-provision_1 | 2022-02-06 11:18:51 [BOOTSTRAP] 5219372284a6 [!] ERROR: FRONTEND: Bootstrap failed - TERMINATE
opennebula-provision_1 | 2022-02-06 11:18:51,679 WARN received SIGTERM indicating exit request
opennebula-provision_1 | 2022-02-06 11:18:51,680 INFO waiting for bootstrap, crond, supervisor-listener to die
opennebula-provision_1 | 2022-02-06 11:18:51,680 INFO exited: bootstrap (exit status 4; not expected)
opennebula-provision_1 | 2022-02-06 11:18:51,698 INFO stopped: supervisor-listener (exit status 0)
opennebula-provision_1 | 2022-02-06 11:18:51,703 INFO stopped: crond (exit status 0)
I’m curious at the line:
Is this a bug or something broken in the configuration?
Regards,
Fadjar Tandabawana
I tried everything following the documentation, even using single container but no luck.
Is there any help that I should follow?
Below my .env file
OPENNEBULA_HOST="one.mydomain.com"
OPENNEBULA_SSH_HOST="one.mydomain.com"
ONEADMIN_PASSWORD="oneadmin"
DEPLOY_BIND_ADDR="10.14.11.100"
DEPLOY_BIND_SSH_ADDR="10.14.11.100"
MYSQL_PASSWORD="oneadmin"
MYSQL_ROOT_PASSWORD="oneadmin"
The core service always restarting after several seconds, only memcahced, guacd, opennebula-docker and scheduler that seems working normally.
Please help to find the culprit and I can run this in my dev environment.
Regards,
Fadjar Tandabawana
Yoooo…
After reinstall the Rocky Linux from scratch, now the opennebula running well as expected…
Regards,
Fadjar Tandabawana
