Hi All,
I am trying to directly attach a host NIC to a guest VM.
I did enable IOMMU at the host, and adjusted the filters at /var/lib/one/remotes/etc/im/kvm-probes.d/pci.conf so as to be able to view the detected PCI devices at the host PCI tab.
When I try to attach a NIC using a PCI NIC device I get the error ATTACHNIC: Missing VN_MAD, BRIDGE, TARGET or MAC in VM NIC at the VM logs. This seems that I need to provide more information when defining the network but I am not sure what I am missing, since I just need to passthrough the device to the VM without defining any VLAN IDs or bridges. How can one attach such a physical device through the Sunstone UI? Is this only possible through raw xml injection into the VM template?
I am attempting this from the Sunstone UI at 6.8.0 OpenNebula version with a single KVM host.
Thanks,
Alex
Host OS: 22.04.4 LTS (where Opennebula runs also)
Opennebula: 6.8.0
VM: Windows 11 64 bit
Enable PCI detection at the host and try to attach one NIC directly to the guest VM as using a passthrough NIC device.
The NIC is not attached at the VM giving the error ATTACHNIC: Missing VN_MAD, BRIDGE, TARGET or MAC in VM NIC
