I’m seeing a confusing failure when I try to deploy a container I downloaded from the Marketplace. I have a system DS defined and ‘oneadmin’ and the nodes can write to it:
DATASTORE 105 INFORMATION
USER : oneadmin
GROUP : oneadmin
CLUSTERS : 0
TYPE : SYSTEM
DS_MAD : -
TM_MAD : ssh
BASE PATH : /var/lib/one//datastores/105
DISK_TYPE : FILE
STATE : READY
DATASTORE CAPACITY
TOTAL: : -
FREE: : -
USED: : -
LIMIT: : -
OWNER : um-
GROUP : u--
OTHER : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="NO"
DISK_TYPE="FILE"
DS_MIGRATE="YES"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
SHARED="NO"
TM_MAD="ssh"
TYPE="SYSTEM_DS"
When I try to deploy and specify this DS I get this:
Wed Oct 14 12:31:30 2020 [Z0][VM][I]: New state is ACTIVE
Wed Oct 14 12:31:30 2020 [Z0][VM][I]: New LCM state is PROLOG
Wed Oct 14 12:31:52 2020 [Z0][VM][I]: New LCM state is BOOT
Wed Oct 14 12:31:52 2020 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/146/deployment.0
Wed Oct 14 12:31:55 2020 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Wed Oct 14 12:31:55 2020 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/lxd/deploy '/var/lib/one//datastores/105/146/deployment.0' 'hpc-onet6' 146 hpc-onet6
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: deploy: Processing disk 0
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: deploy: Using qcow2 mapper for /var/lib/one/datastores/105/146/disk.0
Wed Oct 14 12:31:56 2020 [Z0][VMM][E]: deploy: do_map: Failed to blk_new_open '/var/lib/one/datastores/105/146/disk.0': Could not open '/var/lib/one/datastores/105/146/disk.0': Permission denied
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: deploy: Mapping disk at /var/lib/lxd/storage-pools/default/containers/one-146/rootfs using device
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: deploy: Unmapping disk at /var/lib/lxd/storage-pools/default/containers/one-146/rootfs
Wed Oct 14 12:31:56 2020 [Z0][VMM][E]: deploy: Failed to detect block device from /var/lib/lxd/storage-pools/default/containers/one-146/rootfs
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: deploy: Unmapping disk at /var/lib/one/datastores/105/146/mapper/disk.1
Wed Oct 14 12:31:56 2020 [Z0][VMM][E]: deploy: Failed to detect block device from /var/lib/one/datastores/105/146/mapper/disk.1
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: /var/tmp/one/vmm/lxd/deploy:64:in `<main>': failed to setup container storage (RuntimeError)
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: ExitCode: 1
Wed Oct 14 12:31:56 2020 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Wed Oct 14 12:31:56 2020 [Z0][VMM][E]: Error deploying virtual machine
Wed Oct 14 12:31:56 2020 [Z0][VM][I]: New LCM state is BOOT_FAILURE
Why is it saying deploy: Using qcow2 mapper for /var/lib/one/datastores/105/146/disk.0
when I set up the datastore using the SSH transfer manager? I didn’t change the container image, it’s set to raw. What am I doing wrong?
My LXD host seems to see the datastore fine:
$ onehost show 11
HOST 11 INFORMATION
CLUSTER : default
STATE : MONITORED
IM_MAD : lxd
VM_MAD : lxd
LAST MONITORING TIME : 10/14 12:45:42
LOCAL SYSTEM DATASTORE #105 CAPACITY
TOTAL: : 1T
USED: : 58.7G
FREE: : 1014.3G
