I am currently creating a test environment of an existing productive cloud. The purpose is to evaluate troubles in the upgrade process to a newer version. For that reason I am using older operating system and OpenNebula versions, as they are also used on our real world cloud. I have one controller and two nodes. The nodes have a Glusterfs volume that is mounted to the controller to /var/lib/one. DEBUG_LEVEL is set to 3 in /etc/one/oned.conf.
I can create a VM without a network adapter with no problem, but as soon as I try to create a VM with a network adapter I am receiving the message
DEPLOY: Could not create domain from /var/lib/one//datastores/0/19/deployment.0
The log file /var/log/one/oned.log outputs the following:
Wed Mar 26 10:29:35 2025 [Z0][ReM][D]: Req:7664 UID:0 IP:127.0.0.1 one.vm.deploy invoked , 21, 2, false, 0, ""
Wed Mar 26 10:29:35 2025 [Z0][DiM][D]: Deploying VM 21
Wed Mar 26 10:29:35 2025 [Z0][ReM][D]: Req:7664 UID:0 one.vm.deploy result SUCCESS, 21
Wed Mar 26 10:29:36 2025 [Z0][DBM][I]: Purging obsolete LogDB records: 0 records purged. Log state: 0,0 - 0,0
Wed Mar 26 10:29:36 2025 [Z0][DBM][I]: Purging obsolete federated LogDB records: 0 records purged. Federated log size: 0.
Wed Mar 26 10:29:36 2025 [Z0][ReM][D]: Req:3904 UID:0 IP:127.0.0.1 one.vm.info invoked , 21, false
Wed Mar 26 10:29:36 2025 [Z0][ReM][D]: Req:3904 UID:0 one.vm.info result SUCCESS, "<VM><ID>21</ID><UID>..."
Wed Mar 26 10:29:37 2025 [Z0][TrM][D]: Message received: TRANSFER SUCCESS 21 -
Wed Mar 26 10:29:37 2025 [Z0][VMM][I]: Successfully execute transfer manager driver operation: tm_context.
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: ExitCode: 0
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/mkdir -p.
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/0/21/vm.xml.
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Successfully execute virtualization driver operation: /bin/cat - >/var/lib/one//datastores/0/21/ds.xml.
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy '/var/lib/one//datastores/0/21/deployment.0' '10.0.0.24' 21 10.0.0.24
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: error: Disconnected from qemu:///system due to end of file
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: error: Failed to create domain from /var/lib/one//datastores/0/21/deployment.0
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: error: End of file while reading data: Input/output error
Wed Mar 26 10:29:38 2025 [Z0][VMM][E]: Could not create domain from /var/lib/one//datastores/0/21/deployment.0
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: ExitCode: 255
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: clean: Executed "sudo -n ovs-vsctl --if-exists del-port ovs1 one-21-0".
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Successfully execute network driver operation: clean.
Wed Mar 26 10:29:38 2025 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Wed Mar 26 10:29:38 2025 [Z0][IPM][D]: Message received: DEPLOY FAILURE 21 Could not create domain from /var/lib/one//datastores/0/21/deployment.0
Wed Mar 26 10:29:51 2025 [Z0][ReM][D]: Req:816 UID:0 IP:127.0.0.1 one.zone.raftstatus invoked
Wed Mar 26 10:29:51 2025 [Z0][ReM][D]: Req:816 UID:0 one.zone.raftstatus result SUCCESS, "<RAFT><SERVER_ID>-1<..."
Wed Mar 26 10:29:51 2025 [Z0][ReM][D]: Req:1856 UID:0 IP:127.0.0.1 one.vmpool.infoextended invoked , -2, -1, -1, -1
Wed Mar 26 10:29:51 2025 [Z0][ReM][D]: Req:1856 UID:0 one.vmpool.infoextended result SUCCESS, "<VM_POOL><VM><ID>21<..."
Wed Mar 26 10:29:51 2025 [Z0][ReM][D]: Req:1616 UID:0 IP:127.0.0.1 one.vmpool.infoextended invoked , -2, -1, -1, -1
Wed Mar 26 10:29:51 2025 [Z0][ReM][D]: Req:1616 UID:0 one.vmpool.infoextended result SUCCESS, "<VM_POOL><VM><ID>21<..."
Wed Mar 26 10:30:06 2025 [Z0][ReM][D]: Req:1600 UID:0 IP:127.0.0.1 one.zone.raftstatus invoked
Wed Mar 26 10:30:06 2025 [Z0][ReM][D]: Req:1600 UID:0 one.zone.raftstatus result SUCCESS, "<RAFT><SERVER_ID>-1<..."
Wed Mar 26 10:30:06 2025 [Z0][ReM][D]: Req:5952 UID:0 IP:127.0.0.1 one.vmpool.infoextended invoked , -2, -1, -1, -1
Wed Mar 26 10:30:06 2025 [Z0][ReM][D]: Req:5952 UID:0 one.vmpool.infoextended result SUCCESS, "<VM_POOL><VM><ID>21<..."
Wed Mar 26 10:30:06 2025 [Z0][ReM][D]: Req:1792 UID:0 IP:127.0.0.1 one.vmpool.infoextended invoked , -2, -1, -1, -1
Wed Mar 26 10:30:06 2025 [Z0][ReM][D]: Req:1792 UID:0 one.vmpool.infoextended result SUCCESS, "<VM_POOL><VM><ID>21<..."
In /var/log/one/sched.log I could find:
Wed Mar 26 10:29:35 2025 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Priority Host System DS
21 0 2 0
The datastores by themselves shown by onedatastore list look good. I already fixed the known issue with a system datastore with unknown size percentage in the past.
ID NAME SIZE AVA CLUSTERS IMAGES TYPE DS TM STAT
2 files 20G 97% 0 0 fil fs ssh on
1 default 20G 97% 0 1 img fs qcow2 on
0 system 20G 97% 0 0 sys - qcow2 on
The network adapter is planned to be bridged with Open vSwitch to a real adapter. Configuration looks like:
BRIDGE = "ovs1"
DESCRIPTION = "Connect the VM to a local network with internet access through a NAT"
DNS = "XXX.XXX.XXX.XXX"
FILTER_IP_SPOOFING = "YES"
FILTER_MAC_SPOOFING = "YES"
GATEWAY = "10.10.10.1"
NETWORK_ADDRESS = "10.10.10.0"
NETWORK_MASK = "255.255.254.0"
OUTER_VLAN_ID = ""
PHYDEV = ""
SECURITY_GROUPS = "0"
VLAN_ID = "2"
VN_MAD = "ovswitch"
When I connect via SSH to one of the nodes, I can see that the ovs1 interface exists by entering ip a in the shell:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: sfp0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 08:00:27:2e:07:26 brd ff:ff:ff:ff:ff:ff
inet XX.XX.XX.XX/23 brd 10.0.1.255 scope global sfp0
inet6 fe80::a00:27ff:fe2e:726/64 scope link
3: net1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel master ovs-system state UP group default qlen 1000
link/ether 08:00:27:45:e5:bb brd ff:ff:ff:ff:ff:ff
inet6 fe80::a00:27ff:fe45:e5bb/64 scope link
4: ovs-system: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 92:17:23:b0:a0:22 brd ff:ff:ff:ff:ff:ff
5: ovs1: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
6: virbr0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default qlen 1000
link/ether 52:54:00:ea:5a:46 brd ff:ff:ff:ff:ff:ff
inet 192.168.122.1/24 brd 192.168.122.255 scope global virbr0
7: virbr0-nic: <BROADCAST,MULTICAST> mtu 1500 qdisc fq_codel master virbr0 state DOWN group default qlen 1000
I get additional information with sudo ovs-vsctl show:
dbdae4bb-0000-4858-802e-15522ffd0000
Bridge ovs1
Port ovs1
Interface ovs1
type: internal
Port net1
Interface net1
ovs_version: "2.13.8"
I am using the following software versions:
Operating system: Ubuntu 20.04.6 LTS
OpenNebula version: 6.0.0.3
Thank you in advance
