Hi
I have read the previous posts on this topic and have not been able to resolve the issue.
My LDAP setup for simple LDAP-Active Directory on port 389. The DC is on the same network as the vonecloud server so Firewalls are not an issue.
:order:
- DChostname
DChostname:
:mapping_generate: true
:mapping_timeout: 300
:mapping_filename: server1.yaml
:mapping_key: GROUP_DN
:mapping_default: 1
:auth_method: :simple
:host: DChostname
:port: 389
:base: ou=users,ou=infrastructure,ou=users,ou=business services,ou=mydomain,dc=tld
:user_field: sAMAccountName
Output of ‘ruby -wd /var/lib/one/remotes/auth/ldap/authenticate poceallaigh - MyPassword’
Exception LoadError' at /usr/share/rubygems/rubygems.rb:1096 - cannot load such file -- rubygems/defaults/ruby ExceptionLoadError’ at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55 - cannot load such file – abrt
Exception LoadError' at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:141 - cannot load such file -- abrt /var/lib/one/remotes/auth/ldap/authenticate:42: warning: assigned but unused variable - pass ExceptionNameError’ at /usr/share/ruby/psych/core_ext.rb:16 - method to_yaml' not defined in Object ExceptionNameError’ at /usr/share/ruby/psych/core_ext.rb:29 - method yaml_as' not defined in Module ExceptionNameError’ at /usr/share/ruby/psych/deprecated.rb:80 - undefined method to_yaml_properties' for classObject’
/usr/lib/one/ruby/opennebula/xml_utils.rb:90: warning: -' after local variable is interpreted as binary operator /usr/lib/one/ruby/opennebula/xml_utils.rb:90: warning: even though it seems like unary operator /usr/lib/one/ruby/opennebula/xml_pool.rb:25: warning: method redefined; discarding old initialize /usr/lib/one/ruby/opennebula/xml_element.rb:406: warning: previous definition of initialize was here /usr/lib/one/ruby/opennebula/xml_pool.rb:31: warning: method redefined; discarding old each_element /usr/lib/one/ruby/opennebula/xml_element.rb:412: warning: previous definition of each_element was here ExceptionLoadError’ at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55 - cannot load such file – nokogiri
Exception LoadError' at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55 - cannot load such file -- ox ExceptionLoadError’ at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55 - cannot load such file – xmlparser
Exception LoadError' at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:141 - cannot load such file -- xmlparser /usr/lib/one/ruby/opennebula/virtual_machine_pool.rb:297: warning: assigned but unused variable - acct_hash /usr/lib/one/ruby/opennebula/host.rb:125: warning: ambiguous first argument; put parentheses or even spaces /usr/lib/one/ruby/opennebula/vdc.rb:176: warning: method redefined; discarding old add_host /usr/lib/one/ruby/opennebula/vdc.rb:164: warning: previous definition of add_host was here /usr/lib/one/ruby/opennebula/vdc.rb:192: warning: method redefined; discarding old del_host /usr/lib/one/ruby/opennebula/vdc.rb:186: warning: previous definition of del_host was here ExceptionLoadError’ at /usr/share/rubygems/rubygems/core_ext/kernel_require.rb:55 - cannot load such file – net/ldap
/usr/local/share/gems/gems/net-ldap-0.11/lib/net/ldap/password.rb:22: warning: assigned but unused variable - attribute_value
/usr/local/share/gems/gems/net-ldap-0.11/lib/net/ldap/instrumentation.rb:15: warning: shadowing outer local variable - payload
/usr/local/share/gems/gems/net-ldap-0.11/lib/net/ldap/connection.rb:366: warning: assigned but unused variable - sort_control
Trying server kolsdc
Exception Errno::EAGAIN' at /usr/share/ruby/net/protocol.rb:153 - Resource temporarily unavailable - read would block ExceptionErrno::EAGAIN’ at /usr/share/ruby/net/protocol.rb:153 - Resource temporarily unavailable - read would block
User poceallaigh not found
Could not authenticate user poceallaigh
From the oned.log:
Thu Feb 4 16:56:40 2016 [Z0][AuM][D]: Message received: LOG I 132 Command execution fail: /var/lib/one/remotes/auth/ldap/authenticate poceallaigh - ****
Thu Feb 4 16:56:40 2016 [Z0][AuM][I]: Command execution fail: /var/lib/one/remotes/auth/ldap/authenticate poceallaigh - ****
Thu Feb 4 16:56:40 2016 [Z0][AuM][D]: Message received: LOG I 132 Trying server kolsdc
Thu Feb 4 16:56:40 2016 [Z0][AuM][I]: Trying server kolsdc
Thu Feb 4 16:56:40 2016 [Z0][AuM][D]: Message received: LOG I 132 User poceallaigh not found
Thu Feb 4 16:56:40 2016 [Z0][AuM][I]: User poceallaigh not found
Thu Feb 4 16:56:40 2016 [Z0][AuM][D]: Message received: LOG I 132 Could not authenticate user poceallaigh
Thu Feb 4 16:56:40 2016 [Z0][AuM][I]: Could not authenticate user poceallaigh
Thu Feb 4 16:56:40 2016 [Z0][AuM][D]: Message received: LOG I 132 ExitCode: 255
Thu Feb 4 16:56:40 2016 [Z0][AuM][I]: ExitCode: 255
Thu Feb 4 16:56:40 2016 [Z0][AuM][D]: Message received: AUTHENTICATE FAILURE 132 -
Thu Feb 4 16:56:40 2016 [Z0][AuM][E]: Auth Error:
Thu Feb 4 16:56:40 2016 [Z0][ReM][D]: Req:7600 UID:-1 UserInfo invoked , -1
Thu Feb 4 16:56:40 2016 [Z0][ReM][E]: Req:7600 UID:- UserInfo result FAILURE [UserInfo] User couldn’t be authenticated, aborting call.
Thu Feb 4 16:56:51 2016 [Z0][ReM][D]: Req:7760 UID:2 UserInfo invoked , -1
My account definitely exists and is active.
Any help or further diagnostics I can would be very helpful.
Cheers,
Paraic
