I’m experimenting with a brand new OpenNebula 4.12 all-in-one install on Ubuntu 15.04 and seem to be having an issue with getting any VMs to start. I’ve created storage and templates but when deploying VMs they immediately go to failed. The logs show the below:
Tue Jun 9 23:11:16 2015 [Z0][DiM][I]: New VM state is ACTIVE.
Tue Jun 9 23:11:16 2015 [Z0][LCM][I]: New VM state is PROLOG.
Tue Jun 9 23:11:17 2015 [Z0][LCM][I]: New VM state is BOOT
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/12/deployment.0
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: ExitCode: 0
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy ‘/altairzfsmain/VMs/system/100/12/deployment.0’ ‘altair’ 12 altair
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: error: Failed to create domain from /altairzfsmain/VMs/system/100/12/deployment.0
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: error: internal error: process exited while connecting to monitor: 2015-06-09T22:11:17.658127Z qemu-system-x86_64: -drive file=/altairzfsmain/VMs/system/100/12/disk.0,if=none,id=drive-ide0-0-1,format=qcow2,cache=none: file system may not support O_DIRECT
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: 2015-06-09T22:11:17.658337Z qemu-system-x86_64: -drive file=/altairzfsmain/VMs/system/100/12/disk.0,if=none,id=drive-ide0-0-1,format=qcow2,cache=none: could not open disk image /altairzfsmain/VMs/system/100/12/disk.0: Could not open ‘/altairzfsmain/VMs/system/100/12/disk.0’: Invalid argument
Tue Jun 9 23:11:17 2015 [Z0][VMM][E]: Could not create domain from /altairzfsmain/VMs/system/100/12/deployment.0
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: ExitCode: 255
Tue Jun 9 23:11:17 2015 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Tue Jun 9 23:11:17 2015 [Z0][VMM][E]: Error deploying virtual machine: Could not create domain from /altairzfsmain/VMs/system/100/12/deployment.0
Tue Jun 9 23:11:17 2015 [Z0][DiM][I]: New VM state is FAILED
Listing of the images:
oneadmin@altair:/altairzfsmain/VMs/system/101$ ls -l
total 93847
-rw-r–r-- 1 oneadmin oneadmin 108419072 Jun 3 08:33 23593b00380a15965609dec11d73eac5
-rw-r–r-- 1 oneadmin oneadmin 1048576001 Jun 9 15:47 26f3472d6ce367902b1f3148d40733de
-rw-r–r-- 1 oneadmin oneadmin 0 Jun 9 23:02 3ab68c6be4ee3be76643b0dddfc3de30
-rw-r–r-- 1 oneadmin oneadmin 197120 Jun 3 08:34 572caa85c4261e0a9d5506d0e03e556e
-rw-r–r-- 1 oneadmin oneadmin 197120 Jun 9 23:08 7711af5b3c9eb59beaa260cfb63c515f
-rw-r–r-- 1 oneadmin oneadmin 0 Jun 9 23:02 c765a0c4356d4f07b79c46c2dcc474a6
7711af… is the blank disk associated with the above VM that tried to boot:
oneadmin@altair:/altairzfsmain/VMs/system/101$ file 7711af5b3c9eb59beaa260cfb63c515f
7711af5b3c9eb59beaa260cfb63c515f: QEMU QCOW Image (v3), 2202009600 bytes
Anyone have any ideas what I may be missing?
Thanks,
John
