Please, please … tell me that i can recover my VM after shutdown
i had a fully configured VM as mail server et receioving emails since month… today i wanted to power it of and “restart” it so i used the shutdown command, result : VM disappeared and now more folder of the VMID in the datastore does it mean we have lost every data in that VM !?
The state is “DONE, LCM_INIT”
thanks jfontan & anandharaj,
unfortunately i did not set it as persistant …
Why is it called SHUTDOWN !? this word has already a meaning in IT world ( to poweroff a computer)
Why to set template as persistant ? (because a template is meant to be used by different vm … i don’t see a user case for setting a template as persistent … the vm has already its disk persisted …
Please refer to the documentation to understand the VM lifecyle and meaning of the action. I had the same to understand the “shutdown”.
BTW, there is no setting to set template as persistent, what need to set is the image/disk. So you mentioned the image/dick is already set persistent, then you may just instantiate the template again.
For image with persistent, you need to have template for each image/VM else you need to update the disk information every time you want instantiate a VM. For non-persistent image, yes you just need a single template because the image will be cloned and run from it. When “shutdown”, the cloned image will be deleted.
