Hi all,
I’m use OpenNebula 5.12v with front-end and node in same physical server. And i have HPE StoreOnce 2700 Storage system. I want to add this storage to opennebula.
sudo mount -t nfs 192.168.X.X:/nas/Share_2 /mnt/nfs
And i create system and image datastore with shared mode. Then create image and system folder inside /mnt/nfs (/mnt/nfs/system, /mnt/nfs/image) .Last, i create symbolic link this folders to /var/lib/one/ and change permissions to oneadmin.
When i create new persistent virtual machine get following errors:
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: ln: Linking /var/lib/one/datastores/122/c520584297741d1db1aae2f5e7e2f8bd in localhost:/var/lib/one//datastores/123/37/disk.0
Mon Nov 23 21:45:44 2020 [Z0][TM][E]: ln: Command " set -ex -o pipefail
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: cd /var/lib/one/datastores/123/37
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: rm -f /var/lib/one/datastores/123/37/disk.0
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: ln -s "/var/lib/one/datastores/122/c520584297741d1db1aae2f5e7e2f8bd" "/var/lib/one/datastores/123/37/disk.0"" failed: + cd /var/lib/one/datastores/123/37
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: + rm -f /var/lib/one/datastores/123/37/disk.0
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: + ln -s /var/lib/one/datastores/122/c520584297741d1db1aae2f5e7e2f8bd /var/lib/one/datastores/123/37/disk.0
Mon Nov 23 21:45:44 2020 [Z0][TM][I]: ln: failed to create symbolic link '/var/lib/one/datastores/123/37/disk.0': Input/output error
Mon Nov 23 21:45:44 2020 [Z0][TM][E]: Error linking do-nebula01:/var/lib/one//datastores/122/c520584297741d1db1aae2f5e7e2f8bd to localhost:/var/lib/one//datastores/123/37/disk.0
Mon Nov 23 21:45:44 2020 [Z0][TM][E]: Error executing image transfer script: Error linking do-nebula01:/var/lib/one//datastores/122/c520584297741d1db1aae2f5e7e2f8bd to localhost:/var/lib/one//datastores/123/37/disk.0
Mon Nov 23 21:45:44 2020 [Z0][VM][I]: New LCM state is PROLOG_FAILURE
In this case, my strategy is true ?
İ wait yours ideas, thanks for helping …
