Secondary IP addresses not working with security groups
I have a virtual network under “Bridged & Security Groups” mode.
I have a VM with an IP address 185.113.128.31 and an aliased IP address 185.113.128.32.
I am unable to ping from the aliased IP address even though everything appears to be configured correctly. I can ping from the .31 IP address just fine.
From what I can tell, the problem appears to be with ipset.
My iptables rules for this particular VM are:
Chain opennebula (1 references)
target     prot opt source               destination
one-22-1-o  all  --  185.113.128.32       0.0.0.0/0            PHYSDEV match --physdev-in one-22-0 --physdev-is-bridged
one-22-1-i  all  --  0.0.0.0/0            185.113.128.32       PHYSDEV match --physdev-out one-22-0 --physdev-is-bridged
one-22-0-o  all  --  0.0.0.0/0            0.0.0.0/0            PHYSDEV match --physdev-in one-22-0 --physdev-is-bridged
one-22-0-i  all  --  0.0.0.0/0            0.0.0.0/0            PHYSDEV match --physdev-out one-22-0 --physdev-is-bridged
Which makes sense. The outbound chain in question is:
Chain one-22-1-o (1 references)
RETURN     udp  --  0.0.0.0              255.255.255.255      udp spt:68 dpt:67
DROP       all  --  0.0.0.0/0            0.0.0.0/0            ! match-set one-22-1-ip-spoofing src
RETURN     all  --  0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
Which also makes sense. However, the match-set argument for this (via ipset list) is:
# ipset list one-22-0-ip-spoofing
Type: hash:ip
Revision: 4
Header: family inet hashsize 1024 maxelem 65536
Size in memory: 296
References: 1
Number of entries: 1
Members:
185.113.128.31
From the above, it appears to be missing the aliased IP address.
If I run ipset add one-22-0-ip-spoofing 185.113.128.32 then I can ping from the IP address correctly.
Is this a bug? This is with OpenNebula 6.0.0.2.
Thanks,
Marc
Hello @gigatux,
Did you add the IP alias by using OpenNebula or manually from inside the VM?
@cgonzalez Using OpenNebula Sunstone.
Hi @gigatux,
You are right, it’s a bug that was fixed in this commit. It will be included in the upcoming OpenNebula releases. Thanks for the heads up.
Cheers.
Hi @rdiaz ,
Thanks for the commit info!
I’ve given it a bit of a bodge-test in my environment, just replacing the affected .rb file which I hope is enough. I think there’s still an issue though.
From what I can see, this now correctly creates a load of rules in the opennebula chain, e.g.:
num   pkts bytes target     prot opt in     out     source               destination
1      280 14442 one-32-2-o  all  --  *      *       185.113.129.159      0.0.0.0/0            PHYSDEV match --physdev-in one-32-0 --physdev-is-bridged
2      337 16851 one-32-2-i  all  --  *      *       0.0.0.0/0            185.113.129.159      PHYSDEV match --physdev-out one-32-0 --physdev-is-bridged
3     2273  181K one-32-1-o  all  --  *      *       185.113.129.158      0.0.0.0/0            PHYSDEV match --physdev-in one-32-0 --physdev-is-bridged
4      272 13351 one-32-1-i  all  --  *      *       0.0.0.0/0            185.113.129.158      PHYSDEV match --physdev-out one-32-0 --physdev-is-bridged
5     3477  262K one-32-0-o  all  --  *      *       0.0.0.0/0            0.0.0.0/0            PHYSDEV match --physdev-in one-32-0 --physdev-is-bridged
6     2221  254K one-32-0-i  all  --  *      *       0.0.0.0/0            0.0.0.0/0            PHYSDEV match --physdev-out one-32-0 --physdev-is-bridged
Outbound packets from 185.113.129.158 correctly skip rules 1 and 2, and enter the chain referenced in the third rule, one-32-1-o. They then correctly pass the match-set in that chain and hits the RETURN target.
However, the packet continues to traverse the opennebula chain, skipping rule 4 and hitting rule 5, which is the one-32-0-o chain:
Chain one-32-0-o (1 references)
1        0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            MAC !02:00:b9:71:00:01
2        0     0 RETURN     udp  --  *      *       0.0.0.0              255.255.255.255      udp spt:68 dpt:67
3     2771  217K DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0            ! match-set one-32-0-ip-spoofing src
4      751 52475 RETURN     all  --  *      *       0.0.0.0/0            0.0.0.0/0            state RELATED,ESTABLISHED
5      338 22913 RETURN     all  --  *      *       0.0.0.0/0            0.0.0.0/0
6        0     0 DROP       all  --  *      *       0.0.0.0/0            0.0.0.0/0
Of course, the one-32-0-ip-spoofing set just contains the primary IP address:
Type: hash:ip
Revision: 4
Size in memory: 248
References: 1
Members:
185.113.129.157
And because this doesn’t match, the packet is dropped.
What are your thoughts? Is there still a bug remaining?
Thanks,
Marc
Hi @gigatux,
After changing the script, you must run onehost sync -f to force synchronization of the scripts on the nodes.
On the other hand, this commit is a fix for IPv6.
Cheers.
Hi @rdiaz ,
Thanks for that. I didn’t know about the synchronisation script - I assumed the SSH connection did the firewall rules.
Using both the update security_groups_iptables.rb and command.rb ended up with deployments totally failing.
Honestly, this could be due to anything as I’m well aware I’m cherry picking two files that are probably related to a whole load of other files in the git HEAD so I’ll back off with this one, at least until this goes into a community release.
Many thanks.
Hi @gigatux
There is an addon-vnfilter that resolves the spoofing related issues with the alias IPs since v5.10 was released…
You could give it a try if you need the functionality.
Best Regards,
