in this current security group setting,
RULE = [ IP = "192.168.100.100", PROTOCOL = "ALL", RULE_TYPE = "inbound", SIZE = "3" ]
does this mean that i am allowing all inbound traffic only from 192.168.100.100, 192.168.100.101, and 192.168.100.102?
Hello @quasiqloud,
Welcome to the forum, hope we can help you.
Yes, your understanding is correct. I’ll suggest you to check the documentation, that will help you a bit to understand how to use groups: Security Groups.
Cheers,
Thank you!
