Sharing resources across users and groups in VDC
Hi Yall,
I have created the Following
ON Version 6.4.0 Community MiniOne
Provider: AWS
Provision: One in every AWS region
VDC:
onevdc list
  ID NAME        GROUPS   CLUSTERS      HOSTS      VNETS DATASTORES
 103 Company B        1        ALL          0          0          0
 102 Company A        1        ALL          0          0          0
   0 default        3        ALL          0          0          0
Group:
Company A Group
Users:
Company-A-Group-Admin
CompAUser1
CompAUser2
Company B Group
Users:
Company-B-Group-Admin
CompBUser1
CompBUser2
Image:
Uploaded from desktop
oneimage show 9
IMAGE 9 INFORMATION
NAME           : Ubuntu 20.04 LTS
USER           : oneadmin
GROUP          : oneadmin
LOCK           : None
DATASTORE      : default
TYPE           : OS
REGISTER TIME  : 08/12 20:59:25
PERSISTENT     : No
SOURCE         : /var/lib/one//datastores/1/e1f821e204b708f199c7f07edef9e13b
PATH           : /var/tmp/1331691520-ubuntu-20044-live-server-amd64iso
FORMAT         : raw
STATE          : rdy
RUNNING_VMS    : 0
OWNER          : uma
GROUP          : um-
OTHER          : u--
IMAGE TEMPLATE
DEV_PREFIX="sd"
VIRTUAL MACHINES
VM Template
TEMPLATE 14 INFORMATION
USER           : oneadmin
GROUP          : Company A Group
LOCK           : None
REGISTER TIME  : 08/12 21:13:16
OWNER          : uma
GROUP          : um-
OTHER          : u--
TEMPLATE CONTENTS
CONTEXT=[
  NETWORK="YES",
CPU="1"
CPU_MODEL=[
  MODEL="host-passthrough" ]
DISK=[
  IMAGE="Ubuntu 20.04 LTS",
  IMAGE_UNAME="oneadmin" ]
GRAPHICS=[
  LISTEN="0.0.0.0",
  TYPE="VNC" ]
HOT_RESIZE=[
  CPU_HOT_ADD_ENABLED="NO",
  MEMORY_HOT_ADD_ENABLED="NO" ]
HYPERVISOR="kvm"
INPUTS_ORDER=""
LOGO="images/logos/ubuntu.png"
MEMORY="8192"
MEMORY_UNIT_COST="MB"
NIC=[
  NETWORK_MODE="auto",
  SSH="YES" ]
PROBLEM:
I can instantiate the VM Template with OneAdmin as Company A Group
The VM Builds fine and shows up in the Company A dashboard.
When logged in as the Admin user for Company A Group I can see the VM Template.
When I attempt to instantiate the VM Template as the Company A Group Admin User I get (User Template includes a restricted attribute DISK.)
I know this was a bug in previous versions, however this was supposed to be resolved in 6.4.0
Please advise.
UPDATE:
Commented out the DISK VM_RESTRICTED_ATTR and the deployment proceeds.
This does not seem to be the best solution. Any feedback would be appreciated.
Update:
Ran into a new issue
[one.cluster.info] User [15] : Not authorized to perform USE CLUSTER [127].
This is the admin user.
The VDC and group have permission to use the cluster.
I am seeing that when i go to
Instance > VM > select a VM.
