Hi all!!
this happens when I try to start a EC2 based host
Mon Jan 25 14:57:40 2016 : Error monitoring Host ec2 (17): Error executing poll
/var/log/one/oned.log
Mon Jan 25 14:56:13 2016 [Z0][ONE][I]: Log level:3 [0=ERROR,1=WARNING,2=INFO,3=DEBUG]
Mon Jan 25 14:56:13 2016 [Z0][ONE][I]: Support for xmlrpc-c > 1.31: yes
Mon Jan 25 14:56:13 2016 [Z0][ONE][I]: Checking database version.
Mon Jan 25 14:56:13 2016 [Z0][ONE][I]: oned is using version 4.13.85 for local_db_versioning
Mon Jan 25 14:56:13 2016 [Z0][ONE][I]: oned is using version 4.11.80 for db_versioning
Mon Jan 25 14:56:13 2016 [Z0][ACL][I]: Starting ACL Manager...
Mon Jan 25 14:56:13 2016 [Z0][ACL][I]: ACL Manager started.
Mon Jan 25 14:56:13 2016 [Z0][VMM][I]: Starting Virtual Machine Manager...
Mon Jan 25 14:56:13 2016 [Z0][LCM][I]: Starting Life-cycle Manager...
Mon Jan 25 14:56:13 2016 [Z0][LCM][I]: Life-cycle Manager started.
Mon Jan 25 14:56:13 2016 [Z0][InM][I]: Starting Information Manager...
Mon Jan 25 14:56:13 2016 [Z0][VMM][I]: Virtual Machine Manager started.
Mon Jan 25 14:56:13 2016 [Z0][InM][I]: Information Manager started.
Mon Jan 25 14:56:13 2016 [Z0][TrM][I]: Starting Transfer Manager...
Mon Jan 25 14:56:13 2016 [Z0][DiM][I]: Starting Dispatch Manager...
Mon Jan 25 14:56:13 2016 [Z0][TrM][I]: Transfer Manager started.
Mon Jan 25 14:56:13 2016 [Z0][DiM][I]: Dispatch Manager started.
Mon Jan 25 14:56:13 2016 [Z0][HKM][I]: Starting Hook Manager...
Mon Jan 25 14:56:13 2016 [Z0][AuM][I]: Starting Auth Manager...
Mon Jan 25 14:56:13 2016 [Z0][AuM][I]: Authorization Manager started.
Mon Jan 25 14:56:13 2016 [Z0][HKM][I]: Hook Manager started.
Mon Jan 25 14:56:13 2016 [Z0][ImM][I]: Starting Image Manager...
Mon Jan 25 14:56:13 2016 [Z0][ImM][I]: Image Manager started.
Mon Jan 25 14:56:14 2016 [Z0][VMM][I]: Loading Virtual Machine Manager drivers.
Mon Jan 25 14:56:14 2016 [Z0][VMM][I]: Loading driver: kvm (KVM)
Mon Jan 25 14:56:14 2016 [Z0][VMM][I]: Driver kvm loaded.
Mon Jan 25 14:56:14 2016 [Z0][VMM][I]: Loading driver: ec2 (XML)
Mon Jan 25 14:56:14 2016 [Z0][VMM][I]: Driver ec2 loaded.
Mon Jan 25 14:56:14 2016 [Z0][InM][I]: Loading Information Manager drivers.
Mon Jan 25 14:56:14 2016 [Z0][InM][I]: Loading driver: collectd
Mon Jan 25 14:56:14 2016 [Z0][InM][I]: Driver collectd loaded
Mon Jan 25 14:56:14 2016 [Z0][InM][I]: Loading driver: kvm
Mon Jan 25 14:56:15 2016 [Z0][InM][I]: Driver kvm loaded
Mon Jan 25 14:56:15 2016 [Z0][InM][I]: Loading driver: ec2
Mon Jan 25 14:56:15 2016 [Z0][InM][I]: Driver ec2 loaded
Mon Jan 25 14:56:15 2016 [Z0][TM][I]: Loading Transfer Manager driver.
Mon Jan 25 14:56:15 2016 [Z0][TM][I]: Transfer manager driver loaded
Mon Jan 25 14:56:15 2016 [Z0][HKM][I]: Loading Hook Manager driver.
Mon Jan 25 14:56:15 2016 [Z0][HKM][I]: Hook Manager loaded
Mon Jan 25 14:56:15 2016 [Z0][ImM][I]: Loading Image Manager driver.
Mon Jan 25 14:56:15 2016 [Z0][ImM][I]: Image Manager loaded
Mon Jan 25 14:56:15 2016 [Z0][AuM][I]: Loading Auth. Manager driver.
Mon Jan 25 14:56:15 2016 [Z0][AuM][I]: Auth Manager loaded
Mon Jan 25 14:56:15 2016 [Z0][ReM][I]: Starting Request Manager...
Mon Jan 25 14:56:15 2016 [Z0][ReM][I]: Starting XML-RPC server, port 2633 ...
Mon Jan 25 14:56:15 2016 [Z0][ReM][I]: Request Manager started.
Mon Jan 25 14:56:15 2016 [Z0][ReM][D]: Req:9664 UID:0 SystemConfig invoked
Mon Jan 25 14:56:15 2016 [Z0][ReM][D]: Req:9664 UID:0 SystemConfig result SUCCESS, "<TEMPLATE><AUTH_MAD>..."
Mon Jan 25 14:56:27 2016 [Z0][InM][D]: Monitoring host ec2 (17)
Mon Jan 25 14:56:28 2016 [Z0][InM][D]: Monitoring datastore default (1)
Mon Jan 25 14:56:28 2016 [Z0][InM][D]: Monitoring datastore files (2)
Mon Jan 25 14:56:28 2016 [Z0][InM][I]: Command execution fail: /var/lib/one/remotes/im/run_probes ec2 /var/lib/one//datastores 4124 20 17 ec2
Mon Jan 25 14:56:28 2016 [Z0][InM][I]: /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require': cannot load such file -- aws-sdk (LoadError)
Mon Jan 25 14:56:28 2016 [Z0][InM][I]: from /usr/lib/ruby/1.9.1/rubygems/custom_require.rb:36:in `require'
Mon Jan 25 14:56:28 2016 [Z0][InM][I]: from /usr/lib/one/ruby/ec2_driver.rb:34:in `<top (required)>'
Mon Jan 25 14:56:28 2016 [Z0][InM][I]: from ./poll:29:in `<main>'
Mon Jan 25 14:56:28 2016 [Z0][InM][E]: Error executing poll
Mon Jan 25 14:56:28 2016 [Z0][InM][I]: ExitCode: 1
Mon Jan 25 14:56:28 2016 [Z0][ONE][E]: Error monitoring Host ec2 (17): Error executing poll
Mon Jan 25 14:56:28 2016 [Z0][ImM][D]: Datastore files (2) successfully monitored.
Mon Jan 25 14:56:28 2016 [Z0][ImM][D]: Datastore default (1) successfully monitored.
Mon Jan 25 14:56:34 2016 [Z0][ImM][D]: Datastore system (0) successfully monitored.
Mon Jan 25 14:56:35 2016 [Z0][InM][D]: Host nodo2 (8) successfully monitored.
Mon Jan 25 14:56:37 2016 [Z0][AuM][D]: Message received: AUTHENTICATE SUCCESS 0 -
Mon Jan 25 14:56:37 2016 [Z0][ReM][D]: Req:672 UID:1 DocumentPoolInfo invoked , -2, -1, -1, 100
Mon Jan 25 14:56:37 2016 [Z0][ReM][D]: Req:672 UID:1 DocumentPoolInfo result SUCCESS, "<DOCUMENT_POOL></DOC..."
Mon Jan 25 14:56:42 2016 [Z0][InM][D]: Monitoring host nodo1 (12)
Mon Jan 25 14:56:43 2016 [Z0][AuM][D]: Message received: AUTHENTICATE SUCCESS 1 -
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:5152 UID:0 UserInfo invoked , -1
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:5152 UID:0 UserInfo result SUCCESS, "<USER><ID>0</ID><GID..."
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:4160 UID:0 GroupInfo invoked , 0
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:4160 UID:0 GroupInfo result SUCCESS, "<GROUP><ID>0</ID><NA..."
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:9168 UID:0 UserInfo invoked , -1
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:9168 UID:0 UserInfo result SUCCESS, "<USER><ID>0</ID><GID..."
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:1840 UID:0 GroupInfo invoked , 0
Mon Jan 25 14:56:43 2016 [Z0][ReM][D]: Req:1840 UID:0 GroupInfo result SUCCESS, "<GROUP><ID>0</ID><NA..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:7440 UID:0 ImagePoolInfo invoked , -2, 0, -2000, -1
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:7440 UID:0 ImagePoolInfo result SUCCESS, "<IMAGE_POOL><IMAGE><..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:8928 UID:0 VirtualNetworkPoolInfo invoked , -2, -1, -1
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:8928 UID:0 VirtualNetworkPoolInfo result SUCCESS, "<VNET_POOL><VNET><ID..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:4896 UID:0 VirtualMachinePoolInfo invoked , -2, 0, -2000, -1
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:4896 UID:0 VirtualMachinePoolInfo result SUCCESS, "<VM_POOL></VM_POOL>"
Mon Jan 25 14:56:44 2016 [Z0][AuM][D]: Message received: AUTHENTICATE SUCCESS 2 -
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:6288 UID:1 SystemConfig invoked
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:6288 UID:1 SystemConfig result SUCCESS, "<TEMPLATE><AUTH_MAD>..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:8336 UID:0 HostPoolInfo invoked
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:8336 UID:0 HostPoolInfo result SUCCESS, "<HOST_POOL><HOST><ID..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:5040 UID:0 VirtualMachinePoolAccounting invoked , -2, 1453125404, -1
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:5040 UID:0 VirtualMachinePoolAccounting result SUCCESS, "<HISTORY_RECORDS><HI..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:4640 UID:0 UserPoolInfo invoked
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:4640 UID:0 UserPoolInfo result SUCCESS, "<USER_POOL><USER><ID..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:6224 UID:0 GroupPoolInfo invoked
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:6224 UID:0 GroupPoolInfo result SUCCESS, "<GROUP_POOL><GROUP><..."
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:688 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:688 UID:0 VirtualMachinePoolInfo result SUCCESS, "<VM_POOL></VM_POOL>"
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:9776 UID:0 VirtualMachinePoolInfo invoked , -2, -1, -1, -1
Mon Jan 25 14:56:44 2016 [Z0][ReM][D]: Req:9776 UID:0 VirtualMachinePoolInfo result SUCCESS, "<VM_POOL></VM_POOL>"
Mon Jan 25 14:56:45 2016 [Z0][AuM][D]: Message received: AUTHENTICATE SUCCESS 3 -
Mon Jan 25 14:56:45 2016 [Z0][ReM][D]: Req:800 UID:0 VirtualMachinePoolAccounting invoked , -2, 1453125404, -1
Mon Jan 25 14:56:45 2016 [Z0][ReM][D]: Req:800 UID:0 VirtualMachinePoolAccounting result SUCCESS, "<HISTORY_RECORDS><HI..."
Mon Jan 25 14:56:45 2016 [Z0][ImM][D]: Datastore system (0) successfully monitored.
Mon Jan 25 14:56:45 2016 [Z0][InM][D]: Host nodo1 (12) successfully monitored.
Mon Jan 25 14:56:51 2016 [Z0][ReM][D]: Req:6528 UID:0 HostPoolInfo invoked
Mon Jan 25 14:56:51 2016 [Z0][ReM][D]: Req:6528 UID:0 HostPoolInfo result SUCCESS, "<HOST_POOL><HOST><ID..."
Mon Jan 25 14:56:52 2016 [Z0][ReM][D]: Req:16 UID:0 HostPoolInfo invoked
Mon Jan 25 14:56:52 2016 [Z0][ReM][D]: Req:16 UID:0 HostPoolInfo result SUCCESS, "<HOST_POOL><HOST><ID..."
Mon Jan 25 14:56:52 2016 [Z0][ReM][D]: Req:8016 UID:0 HostInfo invoked , 17
Mon Jan 25 14:56:52 2016 [Z0][ReM][D]: Req:8016 UID:0 HostInfo result SUCCESS, "<HOST><ID>17</ID><NA..."
Mon Jan 25 14:56:54 2016 [Z0][ImM][D]: Datastore system (0) successfully monitored.
Mon Jan 25 14:56:55 2016 [Z0][InM][D]: Host nodo2 (8) successfully monitored.
Mon Jan 25 14:56:58 2016 [Z0][ReM][D]: Req:8464 UID:0 TemplatePoolInfo invoked , -2, -1, -1
Mon Jan 25 14:56:58 2016 [Z0][ReM][D]: Req:8464 UID:0 TemplatePoolInfo result SUCCESS, "<VMTEMPLATE_POOL><VM..."
Mon Jan 25 14:56:59 2016 [Z0][ReM][D]: Req:3168 UID:0 VirtualMachinePoolInfo invoked , -2, 0, -2000, -1
Mon Jan 25 14:56:59 2016 [Z0][ReM][D]: Req:3168 UID:0 VirtualMachinePoolInfo result SUCCESS, "<VM_POOL></VM_POOL>"
Mon Jan 25 14:57:00 2016 [Z0][ReM][D]: Req:1408 UID:0 TemplatePoolInfo invoked , -2, -1, -1
Mon Jan 25 14:57:00 2016 [Z0][ReM][D]: Req:1408 UID:0 TemplatePoolInfo result SUCCESS, "<VMTEMPLATE_POOL><VM..."
/etc/one/ec2_driver.conf
proxy_uri:
regions:
default:
region_name: us-west-1
access_key_id: AKIAIPEKONN**************
secret_access_key: xvLKplnnTfnwOSDtfln8**********************************
capacity:
m1.small: 5
m1.large: 0
m1.xlarge: 0
us-east-1:
region_name: us-east-1
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
us-west-2:
region_name: us-west-2
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
us-west-1:
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
eu-west-1:
region_name: eu-west-1
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
ap-southeast-1:
region_name: ap-southeast-1
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
ap-southeast-2:
region_name: ap-southeast-2
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
ap-northeast-1:
region_name: ap-northeast-1
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
sa-east-1:
region_name: sa-east-1
access_key_id:
secret_access_key:
capacity:
m1.small:
m1.large:
m1.xlarge:
instance_types:
m1.small:
cpu: 1
memory: 1.7
m1.medium:
cpu: 1
memory: 3.75
m1.large:
cpu: 2
memory: 7.5
m1.xlarge:
cpu: 4
memory: 15
c1.medium:
cpu: 2
memory: 1.7
c1.xlarge:
cpu: 8
memory: 7
cc2.8xlarge:
cpu: 32
memory: 60.5
cg1.4xlarge:
cpu: 16
memory: 22.5
m2.xlarge:
cpu: 2
memory: 17.1
m2.2xlarge:
cpu: 4
memory: 34.2
m2.4xlarge:
cpu: 8
memory: 68.4
cr1.8xlarge:
cpu: 32
memory: 244
hi1.4xlarge:
cpu: 16
memory: 60.5
hs1.8xlarge:
cpu: 17
memory: 117
t1.micro:
cpu: 1
memory: 0.613
t2.micro:
cpu: 1
memory: 1
t2.small:
cpu: 1
memory: 2
t2.medium:
cpu: 2
memory: 4
t2.large:
cpu: 2
memory: 8
m4.large:
cpu: 2
memory: 8
m4.xlarge:
cpu: 4
memory: 16
m4.2xlarge:
cpu: 8
memory: 32
m4.4xlarge:
cpu: 16
memory: 64
m4.10xlarge:
cpu: 40
memory: 160
m3.medium:
cpu: 1
memory: 3.75
m3.large:
cpu: 2
memory: 7.5
m3.xlarge:
cpu: 4
memory: 15
m3.2xlarge:
cpu: 8
memory: 30
c4.large:
cpu: 2
memory: 3.75
c4.xlarge:
cpu: 4
memory: 7.5
c4.2xlarge:
cpu: 8
memory: 15
c4.4xlarge:
cpu: 16
memory: 30
c4.8xlarge:
cpu: 36
memory: 60
c3.large:
cpu: 2
memory: 3.75
c3.xlarge:
cpu: 4
memory: 7.5
c3.2xlarge:
cpu: 8
memory: 15
c3.4xlarge:
cpu: 16
memory: 30
c3.8xlarge:
cpu: 32
memory: 60
g2.2xlarge:
cpu: 8
memory: 15
g2.8xlarge:
cpu: 32
memory: 60
r3.large:
cpu: 2
memory: 15.25
r3.xlarge:
cpu: 4
memory: 30.5
r3.2xlarge:
cpu: 8
memory: 61
r3.4xlarge:
cpu: 16
memory: 122
r3.8xlarge:
cpu: 32
memory: 244
i2.xlarge:
cpu: 4
memory: 30.5
i2.2xlarge:
cpu: 8
memory: 61
i2.4xlarge:
cpu: 16
memory: 122
i2.8xlarge:
cpu: 32
memory: 244
d2.xlarge:
cpu: 4
memory: 30.5
d2.2xlarge:
cpu: 8
memory: 61
d2.4xlarge:
cpu: 16
memory: 122
d2.8xlarge:
cpu: 36
memory: 244
I’ve already did
# gem install aws-sdk-v1
# gem uninstall aws-sdk
but still the same
Thank for your help!!
