i have recently upgraded my system that is using GlusterFS gfapi to deploy VMs and all hypervisors are now not able to boot or deploy or migrate VMs.
Any suggestions where the problem can be ?
Fri Nov 25 11:59:44 2016 [Z0][VM][I]: New state is ACTIVE
Fri Nov 25 11:59:44 2016 [Z0][VM][I]: New LCM state is BOOT_POWEROFF
Fri Nov 25 11:59:44 2016 [Z0][VMM][I]: Generating deployment file: /var/lib/one/vms/67/deployment.5
Fri Nov 25 11:59:44 2016 [Z0][VMM][I]: ExitCode: 0
Fri Nov 25 11:59:44 2016 [Z0][VMM][I]: Successfully execute network driver operation: pre.
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: Command execution fail: cat << EOT | /var/tmp/one/vmm/kvm/deploy '/var/lib/one//datastores/112/67/deployment.5' 'node2[reddacted]' 67 node2[reddacted]
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: error: Failed to create domain from /var/lib/one//datastores/112/67/deployment.5
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: error: internal error: process exited while connecting to monitor: [2016-11-25 10:59:44.744034] I [MSGID: 104045] [glfs-master.c:96:notify] 0-gfapi: New graph 6e6f6465-322d-3139-3734-382d32303136 (0) coming up
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: [2016-11-25 10:59:44.744056] I [MSGID: 114020] [client.c:2113:notify] 0-vmvol-client-0: parent translators are ready, attempting connect on transport
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: [2016-11-25 10:59:44.744323] I [MSGID: 114020] [client.c:2113:notify] 0-vmvol-client-1: parent translators are ready, attempting connect on transport
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: [2016-11-25 10:59:44.744511] I [MSGID: 114020] [client.c:2113:notify] 0-vmvol-client-2: parent translators are ready, attempting connect on transport
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: [2016-11-25 10:59:44.744608] I [rpc-clnt.c:1960:rpc_clnt_reconfig] 0-vmvol-client-1: changing port to 49152 (from 0)
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: [2016-11-25 10:59:44.744709] I [rpc-clnt.c:1960:rpc_clnt_reconfig] 0-vmvol-client-0: changing port to 49152 (from 0)
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: [2016-11-25 10:59:44.744957] I [MSGID: 114057] [client-handshake.c:1437:select_server_supported_programs] 0-vmvol-client-1: Using Program GlusterFS 3.3
Fri Nov 25 11:59:55 2016 [Z0][VMM][E]: Could not create domain from /var/lib/one//datastores/112/67/deployment.5
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: ExitCode: 255
Fri Nov 25 11:59:55 2016 [Z0][VMM][I]: Failed to execute virtualization driver operation: deploy.
Fri Nov 25 11:59:55 2016 [Z0][VMM][E]: Error deploying virtual machine: Could not create domain from /var/lib/one//datastores/112/67/deployment.5
Fri Nov 25 11:59:55 2016 [Z0][VM][I]: New state is POWEROFF
Fri Nov 25 11:59:55 2016 [Z0][VM][I]: New LCM state is LCM_INIT
I can see also this problem in gluster logs while trying to boot
[2016-11-25 11:04:27.969949] I [MSGID: 115029] [server-handshake.c:690:server_setvolume] 0-vmvol-server: accepted client from node2-23889-2016/11/25-11:04:27:972079-vmvol-client-0-0-0 (version: 3.7.17)
[2016-11-25 11:04:37.979296] I [MSGID: 115036] [server.c:552:server_rpc_notify] 0-vmvol-server: disconnecting connection from node2-23889-2016/11/25-11:04:27:972079-vmvol-client-0-0-0
[2016-11-25 11:04:37.979328] W [inodelk.c:404:pl_inodelk_log_cleanup] 0-vmvol-server: releasing lock on 731a2b65-8f11-4012-a09e-74320aff3489 held by {client=0x7fb1e80ee7c0, pid=-6 lk-owner=c41d9978347f0000}
[2016-11-25 11:04:37.979337] W [inodelk.c:404:pl_inodelk_log_cleanup] 0-vmvol-server: releasing lock on 731a2b65-8f11-4012-a09e-74320aff3489 held by {client=0x7fb1e80ee7c0, pid=-6 lk-owner=c41d9978347f0000}
[2016-11-25 11:04:37.979345] I [MSGID: 115013] [server-helpers.c:294:do_fd_cleanup] 0-vmvol-server: fd cleanup on /67/disk.1
[2016-11-25 11:04:38.746825] I [socket.c:3423:socket_submit_reply] 0-tcp.vmvol-server: not connected (priv->connected = -1)
[2016-11-25 11:04:38.754732] E [rpcsvc.c:1329:rpcsvc_submit_generic] 0-rpc-service: failed to submit message (XID: 0x2e6d, Program: GlusterFS 3.3, ProgVers: 330, Proc: 37) to rpc-transport (tcp.vmvol-server)
[2016-11-25 11:04:38.754866] E [server.c:205:server_submit_reply] (-->/usr/lib/x86_64-linux-gnu/libglusterfs.so.0(default_rchecksum_cbk+0x127) [0x7fb1f55ed6b7] -->/usr/lib/x86_64-linux-gnu/glusterfs/3.7.17/xlator/protocol/server.so(server_rchecksum_cbk+0xa9) [0x7fb1ed160f39] -->/usr/lib/x86_64-linux-gnu/glusterfs/3.7.17/xlator/protocol/server.so(server_submit_reply+0x2ce) [0x7fb1ed1577be] ) 0-: Reply submission failed
[2016-11-25 11:04:38.754887] I [MSGID: 101055] [client_t.c:420:gf_client_unref] 0-vmvol-server: Shutting down connection node2-23889-2016/11/25-11:04:27:972079-vmvol-client-0-0-0
Moreover, i found this in Libvirt logs.
qemu-system-x86_64: -drive file=gluster://node1:24007/vmvol/67/disk.1,if=none,id=drive-ide0-0-0,format=qcow2,cache=none: could not open disk image gluster://node1:24007/vmvol/67/disk.1: Could not read L1 table: Bad file descriptor
Regards,
Martin
