Hi all
I’m not sure if this is a known issue or if something was changed in the new version. We are testing the new OpenNebula 5.4.0 release but now OpenNebula refuses to instantiate the VMs that are requesting an IP and MAC address from the VM Network section. We have something like this in our VM template:
NIC=[
  IP="10.0.2.2",
  MODEL="virtio",
  MAC="AA:01:01:01:01:30",
  NETWORK="local.net",
  NETWORK_UNAME="oneadmin" ]
The IP and MAC are available from the VNET, we have created a lease for that with just one IP and one MAC (we set an specific MAC for this AR lease):
AR 210
LEASES         : 0
RANGE                                   FIRST                               LAST
MAC                         AA:01:01:01:01:30                  aa:01:01:01:01:30
IP                                   10.0.2.2                           10.0.2.2
But when we try to instantiate the VM we get this error:
[one.template.instantiate] Error allocating a new virtual machine template. Cannot get IP/MAC lease from virtual network 4.
The VNET id and the AR lease are there but it seems that OpenNebula is not able to find them. We didn’t have this issue until now so I guess that something has changed in 5.4.0. I thought that it was related with a case sensitive issue but it does not matter if I change the MAC to upper case or lower case letters, the result is the same.
The only workaround that I found for the moment is just remove the MAC request from the VM NIC section, in that case the VM starts and uses the correct mac from the AR list.
Any idea about this problem? has anyone else experienced the same issue?
Cheers and  thanks!
Álvaro
