Hi I recently upgraded a one 4.14 installation to one 5.0.2. following the migration documentation. Everything seems to work fine. I see sql errors in the log an am wondering what they tell me:
Tue Oct 11 14:58:13 2016 [Z0][ImM][D]: Datastore files (2) successfully monitored.
Tue Oct 11 14:58:13 2016 [Z0][ImM][D]: Datastore xenImage (113) successfully monitored.
Tue Oct 11 14:58:13 2016 [Z0][ImM][D]: Datastore image-nfs (1) successfully monitored.
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 130, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 131, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 243, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 3, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 56, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 58, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 60, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 73, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ONE][E]: SQL command was: SELECT body FROM vm_pool WHERE oid = 86, error: callback requested query abort
Tue Oct 11 14:58:13 2016 [Z0][ImM][D]: Datastore system-nfs (0) successfully monitored.
Tue Oct 11 14:58:13 2016 [Z0][ImM][D]: Datastore image-drbd (102) successfully monitored.
Tue Oct 11 14:58:14 2016 [Z0][MKP][D]: Marketplace OpenNebula Public (0) successfully monitored.
I had a look in the database to only find out that all these vms with the corresponding ids do not exist anymore, they have been deleted already.
the records seem to be ok in the db, for example:
sqlite3 /var/lib/one/one.db "SELECT body FROM vm_pool WHERE oid = 73;" | xmllint --format -
<?xml version="1.0"?>
<VM>
<ID>73</ID>
<UID>0</UID>
<GID>0</GID>
<UNAME>oneadmin</UNAME>
<GNAME>oneadmin</GNAME>
<NAME>Test WinVM</NAME>
<PERMISSIONS>
<OWNER_U>1</OWNER_U>
<OWNER_M>1</OWNER_M>
<OWNER_A>0</OWNER_A>
<GROUP_U>0</GROUP_U>
<GROUP_M>0</GROUP_M>
<GROUP_A>0</GROUP_A>
<OTHER_U>0</OTHER_U>
<OTHER_M>0</OTHER_M>
<OTHER_A>0</OTHER_A>
</PERMISSIONS>
<LAST_POLL>1466749823</LAST_POLL>
<STATE>6</STATE>
<LCM_STATE>0</LCM_STATE>
<PREV_STATE>6</PREV_STATE>
<PREV_LCM_STATE>0</PREV_LCM_STATE>
<RESCHED>0</RESCHED>
<STIME>1466594749</STIME>
<ETIME>1466953265</ETIME>
<DEPLOY_ID>one-73</DEPLOY_ID>
<MONITORING>
<CPU><![CDATA[0.0]]></CPU>
<DISK_SIZE>
<ID><![CDATA[0]]></ID>
<SIZE><![CDATA[0]]></SIZE>
</DISK_SIZE>
<DISK_SIZE>
<ID><![CDATA[1]]></ID>
</DISK_SIZE>
<MEMORY><![CDATA[0]]></MEMORY>
<NETRX><![CDATA[7859955]]></NETRX>
<NETTX><![CDATA[2905424]]></NETTX>
</MONITORING>
<TEMPLATE>
<AUTOMATIC_REQUIREMENTS><![CDATA[!(PUBLIC_CLOUD = YES)]]></AUTOMATIC_REQUIREMENTS>
<CONTEXT>
<DISK_ID><![CDATA[1]]></DISK_ID>
<TARGET><![CDATA[hdb]]></TARGET>
</CONTEXT>
<CPU><![CDATA[1]]></CPU>
<DISK>
<CLONE><![CDATA[YES]]></CLONE>
<CLONE_TARGET><![CDATA[SELF]]></CLONE_TARGET>
<DATASTORE><![CDATA[image-drbd]]></DATASTORE>
<DATASTORE_ID><![CDATA[102]]></DATASTORE_ID>
<DEV_PREFIX><![CDATA[hd]]></DEV_PREFIX>
<DISK_ID><![CDATA[0]]></DISK_ID>
<DISK_SNAPSHOT_TOTAL_SIZE><![CDATA[0]]></DISK_SNAPSHOT_TOTAL_SIZE>
<DRIVER><![CDATA[raw]]></DRIVER>
<IMAGE><![CDATA[Test-WinVM]]></IMAGE>
<IMAGE_ID><![CDATA[18]]></IMAGE_ID>
<IMAGE_UNAME><![CDATA[oneadmin]]></IMAGE_UNAME>
<LN_TARGET><![CDATA[NONE]]></LN_TARGET>
<READONLY><![CDATA[NO]]></READONLY>
<SAVE><![CDATA[NO]]></SAVE>
<SIZE><![CDATA[35840]]></SIZE>
<SOURCE><![CDATA[OpenNebula-image-18]]></SOURCE>
<TARGET><![CDATA[hda]]></TARGET>
<TM_MAD><![CDATA[drbdmanage]]></TM_MAD>
<TYPE><![CDATA[FILE]]></TYPE>
</DISK>
<GRAPHICS>
<PORT><![CDATA[5998]]></PORT>
<TYPE><![CDATA[vnc]]></TYPE>
</GRAPHICS>
<INPUT>
<BUS><![CDATA[usb]]></BUS>
<TYPE><![CDATA[mouse]]></TYPE>
</INPUT>
<MEMORY><![CDATA[4096]]></MEMORY>
<NIC>
<AR_ID><![CDATA[0]]></AR_ID>
<BRIDGE><![CDATA[br0]]></BRIDGE>
<IP><![CDATA[172.16.143.126]]></IP>
<MAC><![CDATA[02:00:ac:10:8f:7e]]></MAC>
<NETWORK><![CDATA[pocnet1]]></NETWORK>
<NETWORK_ID><![CDATA[0]]></NETWORK_ID>
<NETWORK_UNAME><![CDATA[oneadmin]]></NETWORK_UNAME>
<NIC_ID><![CDATA[0]]></NIC_ID>
<SECURITY_GROUPS><![CDATA[0]]></SECURITY_GROUPS>
<VLAN><![CDATA[NO]]></VLAN>
</NIC>
<OS>
<BOOT><![CDATA[hd]]></BOOT>
</OS>
<SECURITY_GROUP_RULE>
<PROTOCOL><![CDATA[ALL]]></PROTOCOL>
<RULE_TYPE><![CDATA[OUTBOUND]]></RULE_TYPE>
<SECURITY_GROUP_ID><![CDATA[0]]></SECURITY_GROUP_ID>
<SECURITY_GROUP_NAME><![CDATA[default]]></SECURITY_GROUP_NAME>
</SECURITY_GROUP_RULE>
<RULE_TYPE><![CDATA[INBOUND]]></RULE_TYPE>
<TEMPLATE_ID><![CDATA[3]]></TEMPLATE_ID>
<VCPU><![CDATA[4]]></VCPU>
<VMID><![CDATA[73]]></VMID>
</TEMPLATE>
<USER_TEMPLATE>
<ACPI><![CDATA[yes]]></ACPI>
<HYPERVISOR><![CDATA[kvm]]></HYPERVISOR>
</USER_TEMPLATE>
<HISTORY_RECORDS>
<HISTORY>
<OID>73</OID>
<SEQ>1</SEQ>
<HOSTNAME>poc1</HOSTNAME>
<HID>5</HID>
<CID>-1</CID>
<STIME>1466594803</STIME>
<ETIME>1466749823</ETIME>
<VMMMAD>kvm</VMMMAD>
<VNMMAD>dummy</VNMMAD>
<TMMAD>shared</TMMAD>
<DS_LOCATION>/var/lib/one//datastores</DS_LOCATION>
<DS_ID>0</DS_ID>
<PSTIME>1466594804</PSTIME>
<PETIME>1466594808</PETIME>
<RSTIME>1466594808</RSTIME>
<RETIME>1466749823</RETIME>
<ESTIME>0</ESTIME>
<EETIME>0</EETIME>
<REASON>2</REASON>
<ACTION>20</ACTION>
</HISTORY>
</HISTORY_RECORDS>
</VM>
- what do these errors want to tell me?
- why are these vms still in the database when they are actually already deleted? is this expected behaviour?
it’s not urgent the system is working fine at the moment, I am just wondering…
thanks!
all the best
Jojo
