I have fresh installed opennebula 6.6.0. I want to create host. but always have the same error after initializing it. Password-less ssh for oneadmin user to host was added.
monitor.log file shows:
Sat Sep 23 07:13:37 2023 [Z0][HMM][D]: Monitoring host localhost(4)
Sat Sep 23 07:13:38 2023 [Z0][MDP][I]: Command execution failed (exit code: 23): exec 2>/dev/null; rsync -Laz --delete ‘/var/lib/one/remotes’/ ‘localhost’:‘/var/tmp/one’/
Sat Sep 23 07:13:38 2023 [Z0][MDP][W]: Start monitor failed for host 4: Could not update remotes
Sat Sep 23 07:13:38 2023 [Z0][HMM][E]: Unable to monitor host id: 4
That command is failing. Try to run it manually as oneadmin and you’ll see the error. Note that since the target is localhost, you need to make sure oneadmin can access the same host it is running without a password.
