I’m trying to deploy a server using a template that contains a start_script = “touch /root/TEST.txt” in the context section but it doesn’t work, any suggestions?
Thank you.
Thank you.
my start script looks like this and works:
#!/bin/bash
if [ -d “/etc/this_folder” ]; then
else
mkdir /etc/this_folder
fi
i put a bash script in the start script to rule everytime the VM power ups.
Hello, dont work for me
. My template is:
CONTEXT = [
CONTEXT = “true”,
DNS = “8.8.8.8”,
ETH0_GATEWAY = “192.168.4.1”,
ETH0_IP = “192.168.4.48”,
ETH0_MASK = “255.255.255.192”,
ETH0_NETWORK = “192.168.4.0”,
ETH0_SEARCH_DOMAIN = “mydomain.es”,
HOSTNAME = “redhatAnsible”,
START_SCRIPT_BASE64 = “#!/bin/bash
touch /root/TEST.txt” ]
CPU = “1”
DESCRIPTION = “Máquina virtual creada con ansible”
DISK = [
DRIVER = “qcow2”,
IMAGE = “redhat7.9_ansible”,
IMAGE_UNAME = “oneadmin” ]
GRAPHICS = [
KEYMAP = “es”,
LISTEN = “0.0.0.0”,
TYPE = “VNC” ]
HYPERVISOR = “kvm”
INPUTS_ORDER = “”
LOGO = “images/logos/redhat.png”
MEMORY = “1024”
MEMORY_UNIT_COST = “MB”
NIC = [
NETWORK = “VLAN 1111”,
NETWORK_UNAME = “oneadmin” ]
OS = [
ARCH = “x86_64”,
BOOT = “disk0” ]
SCHED_RANK = “-RUNNING_VMS”
SCHED_REQUIREMENTS = "ID=“5"”
VCPU = “1”
there is any error?
Thank you.
Hello @jeyc,
The problem is that your START_SCRIPT_BASE64 is not in base64 form, you should have something like: IyEvYmluL2Jhc2gKdG91Y2ggL3Jvb3QvVEVTVC50eHQK.
Best,
Álex.
Go to Templates - VMs - select your VM template
Then “update” - “context” - and there you enter the bash script
after that you click on the “update” button and then you’ll see in the template the BASE64 hash mentioned by Alex above me.
I have tried the following:
and I have also tried the following:
but dont work for me
Thank you.
I have managed to make it work by installing the one_context package in the virtual machine and restarting it, but curiously I have lost the IP address. I’m still investigating.
Thank you.
