Setting the language to Chinese in the settings does not work, other languages can be left
Hello @LiuZiyi,
Welcome to this forum. I’ve checked on the Transifex project and Chinese locale is currently at 54%, so that’s probably the reason to not have it available on Sunstone.
You are more than welcome to contribute to the translation for 7.0 (we have just announced a call for translations: https://opennebula.io/blog/community/help-translate-opennebula-7-0/)
Localization shouldn’t take too much, since the strings are not-technical in its majority, you can take a look on the project here: OpenNebula localization | Transifex
Cheers,
OK, thank you very much. Can the old version of the front end still be used?
Yes, but I think you will face the same problem.
