System datastore ID not created for new datastore at /var/lib/one/datastore
HI I’m using version 6.10.1 for a few months now. (Its a great product).
We are starting to see a datastore creation issue as we’ve scaled up in hosts/datastores.
Typically when we add a new datastore within a few seconds the new ID is at /var/lib/one/datastore.
We have NFS mounted “shared” datastores. Once the IDs is created, then I create NFS mount symbolic link to the datastore directory.
Recently we’ve started seeing a huge delay in the ID directory being created on the filesystem at “/var/lib/one/datatore”.
Some times it takes an hour and as long as 24hours+. I’ve tried restarting ‘oned’ process to kick it, but that doesn’t trigger it. I can’t find any error related logs in oned or monitor.
Any suggestion as to where to find the error or what set to trigger it to complete ID setup and monitoring?
Thanks for your time and help,
-_Ken
Here is a one from today:
created via cli as:
oneadmin@s002-openneb:~/ken$ cat system_datastore.txt
NAME = laas-m7-ssd-ds1-s002-nfs15
DISK_TYPE = "FILE"
SHARED = "YES"
TM_MAD = "shared"
TYPE = "SYSTEM_DS"
DATASTORE_CAPACITY_CHECK = "YES"
LIMIT_MB = 1500000
DS_TYPE="ZFS"
oneadmin@s002-openneb:~/ken$ onedatastore create ./system_datastore.txt
I see it quickly, but with values of zero size
 ID NAME        SIZE AVA CLUSTERS IMAGES TYPE DS      TM      STAT
 179 laas-m7-ssd-ds1-s002-nfs15        0M -   0             0 sys  -       shared  on
oneadmin@s002-openneb:~/ken$ onedatastore show 179
DATASTORE 179 INFORMATION
USER           : oneadmin
GROUP          : oneadmin
CLUSTERS       : 0
TYPE           : SYSTEM
DS_MAD         : -
TM_MAD         : shared
BASE PATH      : /var/lib/one//datastores/179
DISK_TYPE      : FILE
STATE          : READY
DATASTORE CAPACITY
TOTAL:         : 0M
FREE:          : 0M
USED:          : 0M
LIMIT:         : 1.4T
OWNER          : um-
GROUP          : u--
OTHER          : ---
DATASTORE TEMPLATE
ALLOW_ORPHANS="FORMAT"
DATASTORE_CAPACITY_CHECK="YES"
DISK_TYPE="FILE"
DS_MIGRATE="YES"
DS_TYPE="ZFS"
LIMIT_MB="1500000"
RESTRICTED_DIRS="/"
SAFE_DIRS="/var/tmp"
SHARED="YES"
TM_MAD="shared"
TYPE="SYSTEM_DS"
IMAGES
checking here the ID is not created on the filesystem.
oneadmin@s002-openneb:~/datastores$
oneadmin@s002-openneb:~/datastores$ ls
0  100  109  111  113  115  117  121  123  125  127  129  131  133  135  137  139  141  143  145  147  149  151  153  155  157  2
1  101  110  112  114  116  120  122  124  126  128  130  132  134  136  138  140  142  144  146  148  150  152  154  156  158  ISO
oneadmin@s002-openneb:~/datastores$ ls *179*
ls: cannot access '*179*': No such file or directory
This log is in oned.log
Fri May 16 16:46:13 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs15 (179)
a normal datastore have a 2nd log like this
Fri May 16 16:45:43 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs9 (117)
Fri May 16 16:45:54 2025 [Z0][ImM][D]: Datastore laas-m7-ssd-ds1-s002-nfs9 (117) successfully monitored.
Also - once the ID appears everything works fine. Usage of datastore and monitoring. Its just stuck starting/creating the ID for some reason.
Waiting a day to use the datastore is becoming a blocking issue.
Any hints on debugging this and how to kick it to get unstuck?
I did try a hack on a different datastore than the logs below after creating new a DS… I tried manually creating the directory on filesystem with proper ID/oneadmin permission. It didn’t help, still not monitored.
Here is some more logs Once it finally created the ID many hours later.
Note this _monitor log with some ID appears before the successful log.
drwxr-xr-x  2 oneadmin oneadmin 4.0K May 17 01:48 179
oneadmin@s002-openneb:~/datastores$ date
Sat May 17 03:36:26 PM UTC 2025
oneadmin@s002-openneb:~/datastores$ grep -B 1 laas-m7-ssd-ds1-s002-nfs15 /var/log/one/oned.log | less
Sat May 17 02:01:28 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs14 (178)
Sat May 17 02:01:28 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs15 (179)
Sat May 17 02:01:44 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs14 (178)
Sat May 17 02:01:44 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs15 (179)
Sat May 17 02:01:59 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs14 (178)
Sat May 17 02:01:59 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs15 (179)
Sat May 17 02:02:09 2025 [Z0][ImM][DDD]: _monitor: VVNFRF9NQj05MDQ3OTEgRlJFRV9NQj0xMTkyMzYyIFRPVEFMX01CPTIwOTcxNTIK
Sat May 17 02:02:09 2025 [Z0][ImM][D]: Datastore laas-m7-ssd-ds1-s002-nfs15 (179) successfully monitored.
Sat May 17 02:02:14 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs14 (178)
Sat May 17 02:02:14 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs15 (179)
Sat May 17 02:02:29 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs14 (178)
Sat May 17 02:02:29 2025 [Z0][ImM][D]: Monitoring datastore laas-m7-ssd-ds1-s002-nfs15 (179)
Sat May 17 02:02:34 2025 [Z0][ImM][DDD]: _monitor: VVNFRF9NQj05MDQ5MjAgRlJFRV9NQj0xMTkyMjMzIFRPVEFMX01CPTIwOTcxNTIK
Sat May 17 02:02:34 2025 [Z0][ImM][D]: Datastore laas-m7-ssd-ds1-s002-nfs15 (179) successfully monitored.
Hello @kemcfarl,
When you create a new system datastore in OpenNebula, the directory under /var/lib/one/datastores/ (e.g., /var/lib/one/datastores/<ID>) is usually created automatically only after a VM is deployed that uses that datastore.
So if you’re not seeing the directory yet, it’s likely because no VMs have been scheduled to use it. Once a VM is launched and the system datastore is used during deployment, OpenNebula should automatically create that path.
My suggestion is to check the documentation about Datastores, to confirm the expected behavior, and if you still thinks it should be different (or if it doesn’t behave as expected), feel free to file an issue: GitHub · Where software is built
Cheers,
