Zeliko
(Zeliko Rebraca)
April 27, 2022, 1:47pm
1
i imported many vm from Vmware.
I have assigned the VMs to a client and set the quotas. RAM and CPU values are calculated correctly while SYSTEM DISK is always at 0. This way I don’t have a correct disk quota value for the client.
The consumption values on the imported datastores are correct.
[image]
ahuertas
(Alejandro Huertas)
May 10, 2022, 7:52am
2
Hello @Zeliko ,
Could you please share the output of onevm show <VM_ID> -x and oneimage show <IMAGE_ID> -x for each VM disk.
Best,
Álex.
Zeliko
(Zeliko Rebraca)
May 10, 2022, 8:56am
3
there are the output:
onevm show 77 -x
<VM>
<ID>77</ID>
<UID>2</UID>
<GID>0</GID>
<UNAME>sdsoluzione</UNAME>
<GNAME>oneadmin</GNAME>
<NAME>vps70. - CLUSTER 01</NAME>
<PERMISSIONS>
<OWNER_U>1</OWNER_U>
<OWNER_M>1</OWNER_M>
<OWNER_A>0</OWNER_A>
<GROUP_U>0</GROUP_U>
<GROUP_M>0</GROUP_M>
<GROUP_A>0</GROUP_A>
<OTHER_U>0</OTHER_U>
<OTHER_M>0</OTHER_M>
<OTHER_A>0</OTHER_A>
</PERMISSIONS>
<LAST_POLL>1652172376</LAST_POLL>
<STATE>3</STATE>
<LCM_STATE>3</LCM_STATE>
<PREV_STATE>3</PREV_STATE>
<PREV_LCM_STATE>3</PREV_LCM_STATE>
<RESCHED>0</RESCHED>
<STIME>1651611052</STIME>
<ETIME>0</ETIME>
<DEPLOY_ID>vm-2082</DEPLOY_ID>
<MONITORING>
<CPU><![CDATA[12.98]]></CPU>
<DISKRDBYTES><![CDATA[0]]></DISKRDBYTES>
<DISKRDIOPS><![CDATA[0]]></DISKRDIOPS>
<DISKWRBYTES><![CDATA[1884160]]></DISKWRBYTES>
<DISKWRIOPS><![CDATA[3]]></DISKWRIOPS>
<DISK_0_ACTUAL_PATH><![CDATA[[ST01-16HD-1TB-7K-R10-2HS-H710-1G-2CC] vps70./vps70..vmdk]]></DISK_0_ACTUAL_PATH>
<GUEST_IP_ADDRESSES><![CDATA[xx.xx.xxx.xxx,192.168.7.170]]></GUEST_IP_ADDRESSES>
<ID><![CDATA[77]]></ID>
<MEMORY><![CDATA[5481472]]></MEMORY>
<NETRX><![CDATA[0]]></NETRX>
<NETTX><![CDATA[1044480]]></NETTX>
<TIMESTAMP><![CDATA[1652172376]]></TIMESTAMP>
<VCENTER_ESX_HOST><![CDATA[10.10.5.13]]></VCENTER_ESX_HOST>
<VCENTER_GUEST_STATE><![CDATA[running]]></VCENTER_GUEST_STATE>
<VCENTER_RP_NAME><![CDATA[Priority-High-VM]]></VCENTER_RP_NAME>
<VCENTER_VMWARETOOLS_RUNNING_STATUS><![CDATA[guestToolsRunning]]></VCENTER_VMWARETOOLS_RUNNING_STATUS>
<VCENTER_VMWARETOOLS_VERSION><![CDATA[11365]]></VCENTER_VMWARETOOLS_VERSION>
<VCENTER_VMWARETOOLS_VERSION_STATUS><![CDATA[guestToolsCurrent]]></VCENTER_VMWARETOOLS_VERSION_STATUS>
<VCENTER_VM_NAME><![CDATA[vps70.]]></VCENTER_VM_NAME>
</MONITORING>
<TEMPLATE>
<AUTOMATIC_DS_REQUIREMENTS><![CDATA[("CLUSTERS/ID" @> 101)]]></AUTOMATIC_DS_REQUIREMENTS>
<AUTOMATIC_NIC_REQUIREMENTS><![CDATA[("CLUSTERS/ID" @> 101)]]></AUTOMATIC_NIC_REQUIREMENTS>
<AUTOMATIC_REQUIREMENTS><![CDATA[(CLUSTER_ID = 101) & !(PUBLIC_CLOUD = YES) & !(PIN_POLICY = PINNED)]]></AUTOMATIC_REQUIREMENTS>
<CONTEXT>
<DISK_ID><![CDATA[1]]></DISK_ID>
<ETH0_DNS><![CDATA[]]></ETH0_DNS>
<ETH0_EXTERNAL><![CDATA[]]></ETH0_EXTERNAL>
<ETH0_GATEWAY><![CDATA[]]></ETH0_GATEWAY>
<ETH0_GATEWAY6><![CDATA[]]></ETH0_GATEWAY6>
<ETH0_IP><![CDATA[xx.xx.xxx.xxx]]></ETH0_IP>
<ETH0_IP6><![CDATA[]]></ETH0_IP6>
<ETH0_IP6_GATEWAY><![CDATA[]]></ETH0_IP6_GATEWAY>
<ETH0_IP6_METHOD><![CDATA[]]></ETH0_IP6_METHOD>
<ETH0_IP6_METRIC><![CDATA[]]></ETH0_IP6_METRIC>
<ETH0_IP6_PREFIX_LENGTH><![CDATA[]]></ETH0_IP6_PREFIX_LENGTH>
<ETH0_IP6_ULA><![CDATA[]]></ETH0_IP6_ULA>
<ETH0_MAC><![CDATA[00:50:56:b4:39:68]]></ETH0_MAC>
<ETH0_MASK><![CDATA[]]></ETH0_MASK>
<ETH0_METHOD><![CDATA[]]></ETH0_METHOD>
<ETH0_METRIC><![CDATA[]]></ETH0_METRIC>
<ETH0_MTU><![CDATA[]]></ETH0_MTU>
<ETH0_NETWORK><![CDATA[]]></ETH0_NETWORK>
<ETH0_SEARCH_DOMAIN><![CDATA[]]></ETH0_SEARCH_DOMAIN>
<ETH0_VLAN_ID><![CDATA[]]></ETH0_VLAN_ID>
<ETH0_VROUTER_IP><![CDATA[]]></ETH0_VROUTER_IP>
<ETH0_VROUTER_IP6><![CDATA[]]></ETH0_VROUTER_IP6>
<ETH0_VROUTER_MANAGEMENT><![CDATA[]]></ETH0_VROUTER_MANAGEMENT>
<ETH1_DNS><![CDATA[]]></ETH1_DNS>
<ETH1_EXTERNAL><![CDATA[]]></ETH1_EXTERNAL>
<ETH1_GATEWAY><![CDATA[]]></ETH1_GATEWAY>
<ETH1_GATEWAY6><![CDATA[]]></ETH1_GATEWAY6>
<ETH1_IP><![CDATA[192.168.7.170]]></ETH1_IP>
<ETH1_IP6><![CDATA[]]></ETH1_IP6>
<ETH1_IP6_GATEWAY><![CDATA[]]></ETH1_IP6_GATEWAY>
<ETH1_IP6_METHOD><![CDATA[]]></ETH1_IP6_METHOD>
<ETH1_IP6_METRIC><![CDATA[]]></ETH1_IP6_METRIC>
<ETH1_IP6_PREFIX_LENGTH><![CDATA[]]></ETH1_IP6_PREFIX_LENGTH>
<ETH1_IP6_ULA><![CDATA[]]></ETH1_IP6_ULA>
<ETH1_MAC><![CDATA[00:50:56:b4:70:66]]></ETH1_MAC>
<ETH1_MASK><![CDATA[]]></ETH1_MASK>
<ETH1_METHOD><![CDATA[]]></ETH1_METHOD>
<ETH1_METRIC><![CDATA[]]></ETH1_METRIC>
<ETH1_MTU><![CDATA[]]></ETH1_MTU>
<ETH1_NETWORK><![CDATA[]]></ETH1_NETWORK>
<ETH1_SEARCH_DOMAIN><![CDATA[]]></ETH1_SEARCH_DOMAIN>
<ETH1_VLAN_ID><![CDATA[]]></ETH1_VLAN_ID>
<ETH1_VROUTER_IP><![CDATA[]]></ETH1_VROUTER_IP>
<ETH1_VROUTER_IP6><![CDATA[]]></ETH1_VROUTER_IP6>
<ETH1_VROUTER_MANAGEMENT><![CDATA[]]></ETH1_VROUTER_MANAGEMENT>
<NETWORK><![CDATA[YES]]></NETWORK>
<SSH_PUBLIC_KEY><![CDATA[]]></SSH_PUBLIC_KEY>
<TARGET><![CDATA[hda]]></TARGET>
</CONTEXT>
<CPU><![CDATA[2]]></CPU>
<DISK>
<ALLOW_ORPHANS><![CDATA[NO]]></ALLOW_ORPHANS>
<CLONE><![CDATA[NO]]></CLONE>
<CLONE_TARGET><![CDATA[SYSTEM]]></CLONE_TARGET>
<CLUSTER_ID><![CDATA[101]]></CLUSTER_ID>
<DATASTORE><![CDATA[ST01-16HD-1TB-7K-R10-2HS-H710-1G-2CC(IMG)]]></DATASTORE>
<DATASTORE_ID><![CDATA[104]]></DATASTORE_ID>
<DEV_PREFIX><![CDATA[sd]]></DEV_PREFIX>
<DISK_ID><![CDATA[0]]></DISK_ID>
<DISK_SNAPSHOT_TOTAL_SIZE><![CDATA[0]]></DISK_SNAPSHOT_TOTAL_SIZE>
<DISK_TYPE><![CDATA[FILE]]></DISK_TYPE>
<DRIVER><![CDATA[vmdk]]></DRIVER>
<FORMAT><![CDATA[vmdk]]></FORMAT>
<IMAGE><![CDATA[vps70.-02]]></IMAGE>
<IMAGE_ID><![CDATA[77]]></IMAGE_ID>
<IMAGE_STATE><![CDATA[8]]></IMAGE_STATE>
<LN_TARGET><![CDATA[NONE]]></LN_TARGET>
<OPENNEBULA_MANAGED><![CDATA[NO]]></OPENNEBULA_MANAGED>
<ORIGINAL_SIZE><![CDATA[51200]]></ORIGINAL_SIZE>
<PERSISTENT><![CDATA[YES]]></PERSISTENT>
<READONLY><![CDATA[NO]]></READONLY>
<SAVE><![CDATA[YES]]></SAVE>
<SIZE><![CDATA[51200]]></SIZE>
<SOURCE><![CDATA[vps70./vps70..vmdk]]></SOURCE>
<TARGET><![CDATA[sda]]></TARGET>
<TM_MAD><![CDATA[vcenter]]></TM_MAD>
<TYPE><![CDATA[FILE]]></TYPE>
<VCENTER_DS_REF><![CDATA[datastore-25]]></VCENTER_DS_REF>
<VCENTER_INSTANCE_ID><![CDATA[f4ca420f-47bf-4da0-ae48-1bce5bd30242]]></VCENTER_INSTANCE_ID>
</DISK>
<GRAPHICS>
<PORT><![CDATA[5977]]></PORT>
<TYPE><![CDATA[vnc]]></TYPE>
</GRAPHICS>
<IMPORTED><![CDATA[YES]]></IMPORTED>
<MEMORY><![CDATA[6144]]></MEMORY>
<NIC>
<AR_ID><![CDATA[71]]></AR_ID>
<BRIDGE><![CDATA[Pubblica-DPortGroup]]></BRIDGE>
<BRIDGE_TYPE><![CDATA[vcenter_port_groups]]></BRIDGE_TYPE>
<IP><![CDATA[xx.xx.xxx.xxx]]></IP>
<MAC><![CDATA[00:50:56:b4:39:68]]></MAC>
<MAC_IMPORTED><![CDATA[00:50:56:a4:ef:b2]]></MAC_IMPORTED>
<NAME><![CDATA[VC_NIC0]]></NAME>
<NETWORK><![CDATA[Pubblica-DPortGroup]]></NETWORK>
<NETWORK_ID><![CDATA[2]]></NETWORK_ID>
<NIC_ID><![CDATA[0]]></NIC_ID>
<SECURITY_GROUPS><![CDATA[0]]></SECURITY_GROUPS>
<TARGET><![CDATA[one-77-0]]></TARGET>
<VCENTER_NET_REF><![CDATA[dvportgroup-109]]></VCENTER_NET_REF>
<VCENTER_PORTGROUP_TYPE><![CDATA[Distributed Port Group]]></VCENTER_PORTGROUP_TYPE>
<VCENTER_SWITCH_NAME><![CDATA[Pubblica-Switch]]></VCENTER_SWITCH_NAME>
<VN_MAD><![CDATA[vcenter]]></VN_MAD>
</NIC>
<NIC>
<AR_ID><![CDATA[75]]></AR_ID>
<BRIDGE><![CDATA[Privata-DPortGroup]]></BRIDGE>
<IP><![CDATA[192.168.7.170]]></IP>
<MAC><![CDATA[00:50:56:b4:70:66]]></MAC>
<MAC_IMPORTED><![CDATA[00:50:56:a4:2b:28]]></MAC_IMPORTED>
<NAME><![CDATA[VC_NIC1]]></NAME>
<NETWORK><![CDATA[Privata-DPortGroup]]></NETWORK>
<NETWORK_ID><![CDATA[1]]></NETWORK_ID>
<NIC_ID><![CDATA[1]]></NIC_ID>
<TARGET><![CDATA[one-77-1]]></TARGET>
<VCENTER_NET_REF><![CDATA[dvportgroup-106]]></VCENTER_NET_REF>
<VCENTER_SWITCH_NAME><![CDATA[Privata-DSwitch]]></VCENTER_SWITCH_NAME>
</NIC>
<OS>
<UUID><![CDATA[23121a3c-3291-4599-a1ca-102c2be108d8]]></UUID>
</OS>
<SECURITY_GROUP_RULE>
<PROTOCOL><![CDATA[ALL]]></PROTOCOL>
<RULE_TYPE><![CDATA[OUTBOUND]]></RULE_TYPE>
<SECURITY_GROUP_ID><![CDATA[0]]></SECURITY_GROUP_ID>
<SECURITY_GROUP_NAME><![CDATA[default]]></SECURITY_GROUP_NAME>
</SECURITY_GROUP_RULE>
<RULE_TYPE><![CDATA[INBOUND]]></RULE_TYPE>
<TM_MAD_SYSTEM><![CDATA[vcenter]]></TM_MAD_SYSTEM>
<VCPU><![CDATA[2]]></VCPU>
<VMID><![CDATA[77]]></VMID>
</TEMPLATE>
<USER_TEMPLATE>
<DESCRIPTION><![CDATA[vCenter Template \
imported by OpenNebula from Cluster ]]></DESCRIPTION>
<HYPERVISOR><![CDATA[vcenter]]></HYPERVISOR>
<LOGO><![CDATA[images/logos/windows8.png]]></LOGO>
<VCENTER_CCR_REF><![CDATA[domain-c7]]></VCENTER_CCR_REF>
<VCENTER_ESX_HOST><![CDATA[10.10.5.15]]></VCENTER_ESX_HOST>
</USER_TEMPLATE>
<HISTORY_RECORDS>
<HISTORY>
<OID>77</OID>
<SEQ>0</SEQ>
<HOSTNAME>CLUSTER 01</HOSTNAME>
<HID>0</HID>
<CID>101</CID>
<ETIME>0</ETIME>
<VM_MAD><![CDATA[vcenter]]></VM_MAD>
<DS_ID>105</DS_ID>
<PSTIME>1651611052</PSTIME>
<PETIME>1651611052</PETIME>
<RSTIME>1651611052</RSTIME>
<RETIME>0</RETIME>
<ESTIME>0</ESTIME>
<EETIME>0</EETIME>
<ACTION>0</ACTION>
<UID>-1</UID>
<GID>-1</GID>
<REQUEST_ID>-1</REQUEST_ID>
</HISTORY>
</HISTORY_RECORDS>
</VM>
oneimage show 77 -x
<IMAGE>
<ID>77</ID>
<UID>0</UID>
<GID>0</GID>
<UNAME>oneadmin</UNAME>
<NAME>vps70.-02</NAME>
<PERMISSIONS>
</PERMISSIONS>
<TYPE>0</TYPE>
<DISK_TYPE>0</DISK_TYPE>
<PERSISTENT>1</PERSISTENT>
<REGTIME>1651611049</REGTIME>
<PATH><![CDATA[vcenter://vps70./vps70..vmdk]]></PATH>
<FS><![CDATA[]]></FS>
<SIZE>51200</SIZE>
<STATE>8</STATE>
<PREV_STATE>8</PREV_STATE>
<RUNNING_VMS>1</RUNNING_VMS>
<CLONING_OPS>0</CLONING_OPS>
<CLONING_ID>-1</CLONING_ID>
<TARGET_SNAPSHOT>-1</TARGET_SNAPSHOT>
<DATASTORE_ID>104</DATASTORE_ID>
<DATASTORE>ST01-16HD-1TB-7K-R10-2HS-H710-1G-2CC(IMG)</DATASTORE>
<VMS>
<ID>77</ID>
</VMS>
<CLONES/>
<APP_CLONES/>
<TEMPLATE>
<VCENTER_IMPORTED><![CDATA[YES]]></VCENTER_IMPORTED>
</TEMPLATE>
<SNAPSHOTS>
<CURRENT_BASE><![CDATA[-1]]></CURRENT_BASE>
<NEXT_SNAPSHOT><![CDATA[0]]></NEXT_SNAPSHOT>
</SNAPSHOTS>
</IMAGE>
ahuertas
(Alejandro Huertas)
May 12, 2022, 7:29am
4
Hello @Zeliko ,
It seems that the image is owned by oneadmin user, quotas doesn’t apply to this user, this is why is not computed.
Best,
Álex.
Zeliko
(Zeliko Rebraca)
May 12, 2022, 7:50am
5
Hello @ahuertas ,
i changed the owner but the quota for system disk it has not changed.
The quota changes only if I create a virtual machine from scratch by importing a template.
Zeliko
(Zeliko Rebraca)
May 23, 2022, 9:18am
6
Hello @ahuertas ,
is it possible to transform images into system datastore? Is it possible to have assistance, even paying for it, since a month has gone by without having a solution?
ahuertas
(Alejandro Huertas)
May 25, 2022, 3:57pm
7
Hello @Zeliko ,
Images cannot be transformed into system datastore, they are completely different concepts. An image is something that is going to be a DISK when the VM template is instantiated, the system datastore is the datastore that contains all the information about running VMs.
You can check opennebula.io for OpenNebula professional services.
Best,
Álex.
