My Image:
SOURCE : /var/lib/one//datastores/101/bf59894738305d5dfc27ac9ce62a0baa
FSTYPE : save_as
STATE : used
RUNNING_VMS : 2
OWNER : um-
GROUP : —
OTHER : —
IMAGE TEMPLATE
DEV_PREFIX=“vd”
DRIVER=“qcow2”
SAVED_DISK_ID=“0”
SAVED_IMAGE_ID=“27”
SAVED_VM_ID=“136”
SAVE_AS_HOT=“YES”
and df -H from my VM
Filesystem Size Used Avail Use% Mounted on
dev 2.1G 0 2.1G 0% /dev
run 2.1G 443k 2.1G 1% /run
/dev/vda2 8.1G 2.9G 4.9G 37% /
tmpfs 2.1G 0 2.1G 0% /dev/shm
tmpfs 2.1G 0 2.1G 0% /sys/fs/cgroup
tmpfs 2.1G 0 2.1G 0% /tmp
tmpfs 415M 0 415M 0% /run/user/0
tmpfs 415M 0 415M 0% /run/user/1000
or from fdisk: /dev/vda2 * 4196352 20479999 16283648 7.8G 83 Linux
Wher can I see the actual size of the disk in either sunstone or oneimage?
