I have 3 opennebula host nodes. Each of them has a shared nfs-mounted system datasource. When I create a new VM via sunstone and set it to use that system datasouce, I see that the VM file is a symlink to another file in a image datasource.
# ls -al /var/lib/one/datastores/106/45/disk.0
lrwxrwxrwx 1 oneadmin oneadmin 60 Apr 5 17:01 /var/lib/one/datastores/106/45/disk.0 → /var/lib/one/datastores/107/bf5fe882b01bb329f664d8a282621c35
Due to the requirements I received, I am trying to set it up so that if I create a new VM via sunstone, and set that VM to use a system datastore, I would like the actual VM image (file) to remain on that system datastore and not be a symlink to the image datastore.
I searched around a bit, and I noticed this:
http://docs.opennebula.org/5.2/deployment/references/oned_conf.html?highlight=clone_target#transfer-driver
- ln_target : determines how the persistent images will be cloned when a new VM is instantiated.
- NONE : The image will be linked and no more storage capacity will be used
- SELF : The image will be cloned in the Images datastore
- SYSTEM : The image will be cloned in the System datastore
… so it looks like LN_TARGET=SYSTEM is what I need. Symlink or not, it’s still on the same system DS. However I am unable to update/edit the current datasource to set this parameter. I also tried creating a new DS template, with LN_TARGET set to what I want, but both sunstone and onedatastore simply ignore my request. I see no errors in any output, but the setting I want simply reverts back to “NONE”
Can someone please help out?
