Is there any configuration way to force an “undeploy” when user power off an instance from inside guest operative system? I have forced power button to undeploy action, but if user shutdowns “correctly” his instances (from the power button in Gnome, for example), instance execute a “power off” and not an undeploy and, then, instances doesn’t free up its resources.
Thanks!
