DaD
(Daniel Dehennin)
1
After our upgrade to 5.0 on our production infrastructure we find another issue: updating the networks VN_MAD.
Before 5.0 it was set per host, now it’s set per network.
now, neither the hosts nor the VN_MAD have the VN_MAD set
I can’t make a reservation: [VirtualNetworkReserve] No VN_MAD in template for Virtual Network.
but the VMs are deployed with the good network driver:
Mon Aug 22 14:12:42 2016 [Z0][VMM][I]: Successfully execute virtualization driver operation: deploy.
Mon Aug 22 14:12:43 2016 [Z0][VMM][I]: post: Executed “sudo ovs-vsctl set Port one-52742-0 tag=4”.
Mon Aug 22 14:12:43 2016 [Z0][VMM][I]: post: Executed “sudo ovs-vsctl set Port one-52742-1 tag=107”.
Any idea?
Regards.
NB: I’m trying to create a new onedb patch to set the VN_MAD, fortunately all our networks use the same. Do you have a better solution?
DaD
(Daniel Dehennin)
2
It seems to be a Sunstone issue:
But the XML definition of the network is good:
<VNET>
<NAME>EOLE</NAME>
<BRIDGE><![CDATA[rectorat]]></BRIDGE>
<PARENT_NETWORK_ID/>
<VN_MAD><![CDATA[ovswitch]]></VN_MAD>
<PHYDEV/>
<VLAN_ID><![CDATA[4]]></VLAN_ID>
<VLAN_ID_AUTOMATIC>0</VLAN_ID_AUTOMATIC>
<USED_LEASES>12</USED_LEASES>
<TEMPLATE>
Regards.
DaD
(Daniel Dehennin)
3
I clicked on the update button to look at what information I had and I saw that the configuration was not correct:
I’ll open an issue since I think it’s a problem either in sunstone looking for information in ATTRIBUTES or in the upgrade process.
Regards.
cmartin
(Carlos Martín)
5
Thank you for reporting this, we’ll schedule it for the next release.
