Hello.
Does someone try to configure virtiofs in OpenNebula virtual machines?
It looks like I can only do that with RAW/DATA ![]()
Hello.
Looks like it Daniel ![]()
Let me ask the team to see if we can give you a proper answer
Cheers,
Thanks.
For information, the use case is sharing some space between VMs, like the RWx volumes in kubernetes since we have a MooseFS storage.
I thought about a dedicated DS_MAD and TM_MAD to automatically provision a new storage space (a directory) in our MooseFS when creating a “disk” and linking it to the running VMS but I don’t think a “disk” can be multi-attached, right?
The next challenging thing is to build the right libvirt domain snippet but I don’t if OpenNebula is pluggable enough for that.
You’d probably missed the PERSISTENT_TYPE in the image attributes ![]()
BR,
Anton
The problem of using OpenNebula for foo long, I did not catch all the new features and missed that one from 6.0. Or more probably, I noticed it, enjoyed it and forgot.
Thanks, I then I create a datasore with a custom DS, setting that PERSISTENT_TYPE and looking how to set the dir source type, this should avoid my needs for virtioFS.
Thanks a lot for the reminder, I’m quite sure I just forgot since that exactly what we need ![]()
