Hi all,
Thank you for looking at my issue. At the moment, I’m trying to see what the issue is with my setup. I have an Opennebula frontend running 4.14.2. I’m seeing something weird with what I think is the datastore monitoring. Below is what I see when I run ps:
[root@opennebula lib]# ps -ef | grep CLUSTER01 | grep ruby
oneadmin 725 688 11 10:16 ? 00:01:15 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 1272 1242 11 09:50 ? 00:04:17 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 2145 2122 11 09:26 ? 00:07:05 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 2658 2635 11 10:22 ? 00:00:37 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 3452 3437 11 09:16 ? 00:08:17 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 3541 3511 11 08:59 ? 00:10:18 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 3636 3609 11 09:44 ? 00:05:05 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 4090 4050 11 09:45 ? 00:04:52 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 5124 5104 11 09:08 ? 00:09:18 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 6643 6606 11 08:54 ? 00:10:55 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 7124 7096 11 09:28 ? 00:06:51 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 8741 8725 11 10:19 ? 00:01:00 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 11227 11202 11 09:25 ? 00:07:15 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 11977 11950 11 09:39 ? 00:05:38 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 14547 14520 11 09:34 ? 00:06:13 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 20937 20915 11 09:55 ? 00:03:46 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 21035 21017 11 09:12 ? 00:08:47 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 21343 21299 11 10:10 ? 00:01:58 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 22081 22050 11 09:02 ? 00:09:59 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 22730 22702 11 10:02 ? 00:02:57 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 23709 23678 11 09:21 ? 00:07:45 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 24135 24107 11 10:05 ? 00:02:32 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 24220 24185 11 10:27 ? 00:00:04 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 26969 26950 11 09:59 ? 00:03:20 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 30421 30392 11 10:09 ? 00:02:06 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
oneadmin 31895 31876 11 10:01 ? 00:03:06 ruby ./vcenter.rb vcenter /var/lib/one//datastores 4124 20 0 CLUSTER01
I don’t understand why this is spawning so many instances. The processes take a lot of CPU resources, leaving the frontend completely drained. Is there something in particular I should be looking for? A misconfiguration of some sort?
Thanks in advance,
Jesus
