Continuing to see timeouts when running virsh commands. Either when opennebula is running them, or when I’m manually running them. This happens when shutting down a VM or booting a VM. It will take several minutes for OpenNebula to recognize that a VM has been shutdown.
Mon Aug 20 11:39:03 2018 [Z0][VMM][I]: error: Failed to destroy domain one-130
Mon Aug 20 11:39:03 2018 [Z0][VMM][I]: error: internal error: connection closed due to keepalive timeout
Mon Aug 20 11:39:03 2018 [Z0][VMM][I]: error: One or more references were leaked after disconnect from the hypervisor
OpenNebula 5.6.0
Hypervisor: Ubuntu 16.04
Shutdown a VM
Run sudo virsh list on the VMs hypervisor.
The command hangs, and it takes several minutes for OpenNebula to recognize that the VM has been shutdown.
The command succeeds, and OpenNebula updates the status of the VM in under a minute.
