Hi All,
A user is hitting this error when resizing a VM, infact they are reducing the resource - not increasing.
So i’ve changed the RESERVED_CPU and RESERVED_MEM to be regative values.
If I interpret the below settings correctly, CPU can be 100% overcommitted, memory 50GB overcommitted. This is a fairly big environment so over committing is going to be necessary.
RESERVED_CPU -100
RESERVED_MEM -52428800
Currently the Allocated CPU is 7700 / 5900 (131%)
The issue I can still reproduce the resize error with my testing account. I can resize the VM using my oneadmin group account.
Have I used the RESERVED values incorrectly?
Any advice is helpful. Thanks.
*Note i’ve set the same on the Cluster as well just in case without any effect.
