I have configured a small OpenNebula environment with a similar OneStor configuration. So, my main server is serving through NFS datastores 1 (images) and 2 (files) and each KVM or Firecracker node is importing theses datastores and have its own datastore 0 (system) locally. With this configuration, TM_MAD must be qcow2 for datatores 0 and 1 (2 could be ssh).
VMs deploy with a good speed, so some big VMs start in a few seconds. However, I can’t migrate (or migrate live) any VMs, because I get some errors. This problem don’t allow me to distribute VMs across all my nodes (KVM and/or Firecracker) in some situations when one KVM is full and VM is “forced” to be scheduled and placed in a determined host.
I have run a small test and I have got some screenshots:
I have added “TM_MAD_SYSTEM=ssh” to all my three datastors (system, default and files), but when I have tried to migrate a VM the errors appears again:
**Driver Error**
Mon Apr 24 13:49:30 2023: RESTORE: ERROR: restore: Command "set -e -o pipefail # extract the xml from the checkpoint virsh --connect qemu:///system save-image-dumpxml /var/lib/one//datastores/0/64/checkpoint > /var/lib/one//datastores/0/64/checkpoint.xml # Eeplace all occurrences of the DS_LOCATION/<DS_ID>/<VM_ID> with the specific # DS_ID where the checkpoint is placed. This is done in case there was a # system DS migration sed -i "s%/var/lib/one//datastores/[0-9]\+/64/%/var/lib/one//datastores/0/64/%g" /var/lib/one//datastores/0/64/checkpoint.xml sed -i "s%/var/lib/one/datastores/[0-9]\+/64/%/var/lib/one//datastores/0/64/%g" /var/lib/one//datastores/0/64/checkpoint.xml" failed: error: Falló al abrir el disco '/var/lib/one//datastores/0/64/checkpoint': No existe el fichero o el directorio Could not recalculate paths in /var/lib/one//datastores/0/64/checkpoint.xml ExitCode: 1
