I am running ceph nautilus and cluster is running properly. I’m having issues getting ceph datastores working properly on my installation, running 5.8.0-1 on Ubuntu18 with a shared file system along with Ceph datastores. I am having issues with migrations between hosts with TM_MAD set to “ceph”.
Here are my Error:
Thu Apr 9 13:47:08 2020 [Z0][TM][I]: Command execution failed (exit code: 2): /var/lib/one/remotes/tm/ceph/mv node3:/var/lib/one//datastores/124/1114 node2:/var/lib/one//datastores/124/1114 1114 124
Thu Apr 9 13:47:08 2020 [Z0][TM][I]: mv: Moving node3:/var/lib/one/datastores/124/1114 to node2:/var/lib/one/datastores/124/1114
Thu Apr 9 13:47:08 2020 [Z0][TM][E]: mv: Command “set -e -o pipefail
Thu Apr 9 13:47:08 2020 [Z0][TM][I]: tar -C /var/lib/one/datastores/124 --sparse -cf - 1114 | ssh node2-dhk-cls1.bol-online.com ‘tar -C /var/lib/one/datastores/124 --sparse -xf -’
Thu Apr 9 13:47:08 2020 [Z0][TM][I]: rm -rf /var/lib/one/datastores/124/1114” failed: tar: 1114: Cannot stat: No such file or directory
Thu Apr 9 13:47:08 2020 [Z0][TM][I]: tar: Exiting with failure status due to previous errors
Thu Apr 9 13:47:08 2020 [Z0][TM][E]: Error copying disk directory to target host
Thu Apr 9 13:47:08 2020 [Z0][TM][E]: Error executing image transfer script: Error copying disk directory to target host
