I have two nodes and for the last two days I’m getting host errors. Host is actually up but here’re the errors from oned.log
Sat Jul 23 15:14:45 2016 [Z0][ONE][E]: Error monitoring Host host-node01 (0): error: failed to connect to the hypervisor
error: error from service: CheckAuthorization: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
ERROR MESSAGE --8<------
Error executing kvm.rb
ERROR MESSAGE ------>8–
ARCH=x86_64
MODELNAME=“Intel® Xeon® CPU E5-2620 0 @ 2.00GHz”
Sat Jul 23 15:15:20 2016 [Z0][ONE][E]: Error monitoring Host host-node01 (0): error: failed to connect to the hypervisor
error: End of file while reading data: Input/output error
ARCH=x86_64
And of course VMs get into UNKNOWN state.
When I restart libvirtd on the host, everything get back OK. How can I check what is the cause?
And another thng that host hook is active and in sched log, it says there’re VMs to be rescheduled but unable to do:
Sat Jul 23 15:23:34 2016 [Z0][VM][D]: Found 5 pending/rescheduling VMs.
Sat Jul 23 15:23:34 2016 [Z0][HOST][D]: Discovered 2 enabled hosts.
Sat Jul 23 15:23:34 2016 [Z0][SCHED][D]: Match-making results for VM 30:
Cannot schedule VM, there is no suitable host.
Sat Jul 23 15:23:34 2016 [Z0][SCHED][D]: Match-making results for VM 34:
Sat Jul 23 15:23:34 2016 [Z0][SCHED][D]: Match-making results for VM 36:
Sat Jul 23 15:23:34 2016 [Z0][SCHED][D]: Match-making results for VM 37:
Sat Jul 23 15:23:34 2016 [Z0][SCHED][D]: Match-making results for VM 39:
Sat Jul 23 15:23:34 2016 [Z0][SCHED][D]: Dispatching VMs to hosts:
VMID Host System DS
How can I cancel those pending reschedule. I dont want to cancel the host hook at all.
Thanks, regards,
Orhan
