Using OpenNebula 5.0 and a VM stuck in SNAPSHOT state. Here’s a brief info about my system:
[oneadmin@fe1 ~]$ onedatastore list
102 nfs_images 896G 98% 0 13 img fs qcow2 on
103 nfs_system 896G 98% 0 0 sys - shared on
[oneadmin@fe1 ~]$ onevm show 28
VIRTUAL MACHINE 28 INFORMATION
USER : oneadmin
GROUP : oneadmin
STATE : ACTIVE
LCM_STATE : HOTPLUG_SNAPSHOT
RESCHED : No
HOST : comp1
CLUSTER ID : 0
CLUSTER : default
START TIME : 06/09 18:31:43
END TIME : -
DEPLOY ID : one-28
VIRTUAL MACHINE MONITORING
CPU : 0.0
MEMORY : 1024M
OWNER : um-
GROUP : —
OTHER : —
VM DISKS
ID DATASTORE TARGET IMAGE SIZE TYPE SAVE
0 nfs_images hda vm-centos6-disk-0 1.4G/30G file YES
1 - hdb CONTEXT 1M/- - -
SNAPSHOTS
ID TIME NAME HYPERVISOR_ID
0 06/10 10:19 vm28-centos6
VIRTUAL MACHINE HISTORY
SEQ HOST ACTION DS START TIME PROLOG
0 comp2 live-migrate 103 06/09 18:35:56 0d 15h42m 0h00m01s
1 comp1 none 103 06/10 10:18:08 0d 00h32m 0h00m00s
USER TEMPLATE
HYPERVISOR="kvm"
LOGO="images/logos/linux.png"
SCHED_REQUIREMENTS="ID=“3” | ID=“4"”
VIRTUAL MACHINE TEMPLATE
AUTOMATIC_DS_REQUIREMENTS="“CLUSTERS/ID” = 0"
AUTOMATIC_REQUIREMENTS="(CLUSTER_ID = 0) & !(PUBLIC_CLOUD = YES)“
CLONING_TEMPLATE_ID=“24"
CONTEXT=[
DISK_ID=“1”,
NETWORK=“YES”,
SSH_PUBLIC_KEY=””,
TARGET=“hdb” ]
CPU="0.3"
GRAPHICS=[
LISTEN=“0.0.0.0”,
PORT=“5928”,
TYPE=“VNC” ]
MEMORY="1024"
OS=[
BOOT=“disk1” ]
TEMPLATE_ID="27"
VMID=“28”
[oneadmin@fe1 ~]$ ll /var/lib/one/datastores/102/
total 8611202
-rw-r–r-- 1 oneadmin oneadmin 1485438976 Jun 9 12:04 0fcfa785f5f35267b6d8c88ecaeaa28a
drwxrwxr-x 2 oneadmin oneadmin 0 Jun 8 12:41 0fcfa785f5f35267b6d8c88ecaeaa28a.snap
-rw-r–r-- 1 oneadmin oneadmin 414187520 Jun 8 12:37 12ea73ddc561a53a36c40d3ca23ef68d
-rw-r–r-- 1 oneadmin oneadmin 197120 Jun 8 12:32 14958fb78c0a126e0f3e5ff97bab1790
-rw-r–r-- 1 oneadmin oneadmin 1102249984 Jun 9 14:25 1e1027f65ad292fadb84a11a8771928c
drwxrwxr-x 2 oneadmin oneadmin 0 Jun 9 12:33 1e1027f65ad292fadb84a11a8771928c.snap
-rw-r–r-- 1 oneadmin oneadmin 197120 Jun 8 12:38 3fe6ef100d06204cd68ac4332c868967
-rw-r–r-- 1 oneadmin oneadmin 1123352576 Jun 10 10:03 59fdd7f0ec980dcfec1f7f6effe4ff64
drwxrwxr-x 2 oneadmin oneadmin 0 Jun 9 18:36 59fdd7f0ec980dcfec1f7f6effe4ff64.snap
-rw-r–r-- 1 oneadmin oneadmin 414187520 Jun 8 12:40 5a4bb1fa3d6a77898bf00bafdbf408bb
-rw-r–r-- 1 oneadmin oneadmin 41943040 Jun 8 12:34 7b896584362209e209ef3aa6ea66410b
-rw-r–r-- 1 oneadmin oneadmin 632291328 Jun 8 18:21 95fcd4f61b0670a2b189ea0172f8f7df
-rw-r–r-- 1 oneadmin oneadmin 632291328 Jun 9 12:33 969e7e7e74035c1ddb887aa80ef6f20e
-rw-r–r-- 1 oneadmin oneadmin 197120 Jun 8 12:31 c1d2501d933512dd139cdccaf0fe80d9
-rw-r–r-- 1 oneadmin oneadmin 1485635584 Jun 9 14:19 e1c9f879d08a19f1e86fb9a5649fd885
drwxrwxr-x 2 oneadmin oneadmin 0 Jun 9 13:35 e1c9f879d08a19f1e86fb9a5649fd885.snap
-rw-r–r-- 1 oneadmin oneadmin 1485701120 Jun 10 10:54 ff607122771c2a785731a7889c19f68d
drwxrwxr-x 2 oneadmin oneadmin 0 Jun 9 18:35 ff607122771c2a785731a7889c19f68d.snap
[oneadmin@fe1 ~]$ ll /var/lib/one/datastores/102/ff607122771c2a785731a7889c19f68d.snap/
total 1
lrwxrwxrwx 1 oneadmin oneadmin 60 Jun 9 18:35 0 -> /var/lib/one/datastores/102/ff607122771c2a785731a7889c19f68d
lrwxrwxrwx 1 oneadmin oneadmin 65 Jun 9 18:35 ff607122771c2a785731a7889c19f68d.snap -> /var/lib/one/datastores/102/ff607122771c2a785731a7889c19f68d.snap
mount (on all nodes and fe): mfs#mfsmaster:9421 on /var/lib/one/datastores type fuse (rw,nosuid,nodev,relatime,user_id=0,group_id=0,default_permissions,allow_other)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
oned.log: Fri Jun 10 10:51:40 2016 [Z0][VMM][D]: VM 28 successfully monitored: DISK_SIZE=[ID=0,SIZE=1417] SNAPSHOT_SIZE=[ID=0,DISK_ID=0,SIZE=1417] DISK_SIZE=[ID=1,SIZE=1]
28.log
Fri Jun 10 10:18:22 2016 [Z0][VM][I]: New LCM state is RUNNING
Fri Jun 10 10:19:24 2016 [Z0][VM][I]: New LCM state is HOTPLUG_SNAPSHOT
Any help would be appreciated.
Orhan
