when opennebula 4.14 will be Release?
this month?
this month?
I’m just guessing here, but since the translation deadline is set to 10 sept. according to this topic:
So probably end of sept. or oct.
You can follow all progress here: http://dev.opennebula.org/versions/74
cheers!
If everything goes as expected we will release a second beta next week. After that we will need some more time to fix outstanding bugs, finish documentation, fine tune packages and so on.
The final release should be this month. I really encourage you to test the betas and report any bugs or strange behavior. It really helps us.
cool,I will test the second beta release and report any bugs. Thanks for your work.
