Hey,
I have a Xen with xl toolstack. To run linux pv vms are fine. vms boot up with no issue, however when I try to run a hvm vm, I get the following error:
Wed Dec 7 09:28:49 2016 [Z0][ReM][D]: Req:9200 UID:3 VirtualMachineInfo invoked , 37
Wed Dec 7 09:28:49 2016 [Z0][ReM][D]: Req:9200 UID:3 VirtualMachineInfo result SUCCESS, "37…"
Wed Dec 7 09:28:49 2016 [Z0][ReM][D]: Req:9392 UID:3 VirtualMachineRecover invoked , 37, 2
Wed Dec 7 09:28:49 2016 [Z0][ReM][D]: Req:9392 UID:3 VirtualMachineRecover result SUCCESS, 37
Wed Dec 7 09:28:49 2016 [Z0][ReM][D]: Req:8640 UID:3 VirtualMachineInfo invoked , 37
Wed Dec 7 09:28:49 2016 [Z0][ReM][D]: Req:8640 UID:3 VirtualMachineInfo result SUCCESS, "37…"
Wed Dec 7 09:28:49 2016 [Z0][VMM][D]: Message received: LOG I 37 Successfully execute transfer manager driver operation: tm_context.
Wed Dec 7 09:28:49 2016 [Z0][VMM][D]: Message received: LOG I 37 ExitCode: 0
Wed Dec 7 09:28:49 2016 [Z0][VMM][D]: Message received: LOG I 37 Successfully execute network driver operation: pre.
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 Command execution fail: cat << EOT | /var/tmp/one/vmm/xen/deploy ‘/var/lib/one//datastores/0/37/deployment.0’ ‘10.1.0.101’ 37 10.1.0.101
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 libxl: error: libxl_dm.c:717:libxl__build_device_model_args_new: qemu-xen doesn’t support read-only disk drivers
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 libxl: error: libxl_dm.c:1393:device_model_spawn_outcome: (null): spawn failed (rc=-3)
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 libxl: error: libxl_create.c:1188:domcreate_devmodel_started: device model did not start: -3
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 libxl: error: libxl_dm.c:1489:kill_device_model: unable to find device model pid in /local/domain/99/image/device-model-pid
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 libxl: error: libxl.c:1437:libxl__destroy_domid: libxl__destroy_device_model failed for 99
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG E 37 Unable
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 ExitCode: 3
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: LOG I 37 Failed to execute virtualization driver operation: deploy.
Wed Dec 7 09:28:53 2016 [Z0][VMM][D]: Message received: DEPLOY FAILURE 37 Unable
The source of the error is, the opennebula has own drive for implementing IP address usename etc. When I change it from hdc,r to hdc,w I can boot it up but from the HV’s command line. Anytime when I click to start on Sunstone, It changes back to the original hdc,r and the VM does not boot up. Any idea how I can fix it?
Many thanks
