It seems that attaching then removing nic from sunstone interface is not working.
I already have one nic attached to a VM. I add a second nic on an ethernet AR. So I have:
ID 0 primary nic
ID 1 temporary secondary nic
when I click on detach on the line of the nic ID 1, it remove the nic id 0. So I now have:
Then click on detach on this last nic, I have an error saying that it can’t detach nic id 0…
Everything works fine using the CLI. Is it a known bug? I don’t think I had this one on 4.10.
