I changed the NIC of a VM in sunstone and it says that the new IP is 10.195.2.6, but if I run ip a in the VM it says that VM’s IP is 10.195.2.8. How can I fix this?
Thank you!
Thank you!
IP configuration for attached nics must be done manually. We are working on contextualization updates for the next release but in 4.x you need to assign the IP manually inside the VM.
